What speedo? STACK, SPA etc etc
Old Apr 28, 2007 | 08:17 PM
rapidcossie's Avatar
rapidcossie
Default What speedo? STACK, SPA etc etc
Looking for ideas for a non standard speedo as I will need one when my new gearbox is fitted.
Pics and opinions please
Old Apr 28, 2007 | 08:31 PM
Stoo's Avatar
Stoo
I think Carlo looked into this in some depth..maybe worth checking with him Euan
Old Apr 28, 2007 | 08:32 PM
Ian M500COS's Avatar
Ian M500COS
Euan
Dont use the small SPA rectangular speedometer kit as it's utter junk!!
I use my Road Angel for speed measurement in my Escort... but at times this is also utter junk!
Old Apr 28, 2007 | 08:33 PM
Jasesapphy's Avatar
Jasesapphy
stack or those AIM MXL things, i suppose
Stack are easier to wire i believe, depends what you want, they do a stack st700 that does Revs, Speed, water/oil temp and oil pressure for about £400 ish, then it goes upto as much as you want really, £1k for a st8130 of rainbum.
Aim dashes start at £500 and do pretty much everything but dependent on what management can be porblematic to fit im told
I dont know a lot about them, only what others have said
Not much help, but it gets it to the top again for you
Old Apr 28, 2007 | 08:36 PM
carlo's Avatar
carlo
I looked into this when the focus was getting built i was thinking more of a full stack dash. i also got andy to speak to frasor(promethious) & he could sort something out like single speedos no probs might be worth speaking to him there were loads to chose from
Old Apr 28, 2007 | 08:37 PM
jon@work's Avatar
jon@work
in what way ?
Old Apr 28, 2007 | 08:39 PM
rapidcossie
in what way ?
yeah in what way?
I liked them cos they are only 160 quid
all the others are fortunes
Old Apr 28, 2007 | 10:49 PM
CozzyBrom's Avatar
CozzyBrom
what dash do you have at the min euan ?
if standard the the spa fits very nicly where the abs light used to go
very good unit ran one for 4 yrs in my saff now i have the rev counter shiftlight speedo all in 1
Old Apr 28, 2007 | 10:58 PM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
Dont you need a working abs light for MOT's
Old Apr 28, 2007 | 11:03 PM
CozzyBrom's Avatar
CozzyBrom
not when its moved somewhere else like the black cowling
Old Apr 29, 2007 | 07:30 AM
CliffRS4's Avatar
CliffRS4
in what way ?
yeah in what way?
I run a Spa Speedo with the sensor off the back wheel. I find it a brilliant bit of kit and as you say Euan the others are stupid money.
Old Apr 29, 2007 | 07:47 AM
Jay,'s Avatar
Jay,
Sponsor
I also run a spa one and checked with gps its spot
Old Apr 29, 2007 | 09:13 AM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
Wish I never sold you it now LOL.. how you finding it.. ?
Old Apr 29, 2007 | 09:31 AM
Ian M500COS
in what way ?
Well out of the 3 I had, every one developed faults. Kept coming up with FFF on the display - had to reset the 1.96m calibration all the time - kept losing its memory, illumination kept going wrong.
The last one I had, I sold it but before I did, sent it back to Spa to have it repaired again. Had it sent direct to the guy who bought it off me (a mate) and surprise surprise it went wrong again - so I gave him his money back and threw it in the bin!!
Not a good experience of this product!!!
Old Apr 29, 2007 | 10:42 AM
foreigneRS's Avatar
foreigneRS
Testing the future
i would just use a gps, but then i already have a PDA or a smartphone with the capability to do it so no extra cost
Old Apr 29, 2007 | 11:55 AM
rapidcossie
Brom will have a look at fitting where you suggest as it looks quite cool
Ian I have had similar probs with my other SPA gauges loosing their memory etc.
I would buy the stack combined rev counter and speedo like Brom talks about but I already have a stack rev counter so seems silly to sell that just to buy another one.
Old Apr 29, 2007 | 12:07 PM
nigel b's Avatar
nigel b
get a AIM or racepak dash and connect it to your ecu
Old Apr 29, 2007 | 12:36 PM
rapidcossie
I would love the AIM dash or something similar but dont want to spend 700 quid plus fitting
The car take enough of my bloody money
Old Apr 29, 2007 | 01:24 PM
Jay,'s Avatar
Jay,
Sponsor
yeh its cool radders reacts well does what it says on the can cant say anymore really
Old Apr 29, 2007 | 01:26 PM
rapidcossie
Was it easy to fit and set up jay?
Old Apr 29, 2007 | 01:31 PM
Jay,'s Avatar
Jay,
Sponsor
when i had standard brakes on the car i fitted to the inner drive shaft cup and a bracket off the beam but now i have ap 330mm its so much better read out and a easier fit the magnet is on one of the bell bolts and the bracket is fitted to the shock . its very easy to fit , the slightly harder bit wat to set it up to read the correct speed i measured the wheel and tyre but it was still out so i used a gps item to set it up and it is spot on
Old Apr 29, 2007 | 01:33 PM
Daviet's Avatar
Daviet
on the mxl and aim dashes i take it all the gauges etc are accurate?
as it may cost 700 but youd probably get quite a bit back on all your gauges and rev counter.and there also all in clear easy view then aswell
id love something like this in my car http://www.racecarsdirect.com/viewlisting.php?view=8750
but i need alot more than a dash
Old Apr 29, 2007 | 01:38 PM
Rippers's Avatar
Rippers
Monte Geek
Now its set up my Stack is 100% spot to my Tom Tom GPS speed
Old Apr 29, 2007 | 01:42 PM
rapidcossie
Will probably set it up on the rollers to ensure its accurate...
I have bells so hopefully it wont be too hard.
Old Apr 29, 2007 | 01:56 PM
Jay,'s Avatar
Jay,
Sponsor
cool now im looking at a full dash now just justify £700+ the only reason i have fittied it was coz i couldnt be arse to strip the gearbox out to fix the speedo drive
Old Apr 29, 2007 | 02:06 PM
M K's Avatar
M K
i have the spa combined tacho/speedo,
not sure how accurate it is low down speeds but at the daddy thrash my recall was 150.1mph and PF's gps gear recall was 149.8mph
never had any trouble with it either
Old Apr 29, 2007 | 02:09 PM
rapidcossie
looks pretty cool marc
Mark RS
Oct 12, 2015 06:01 AM
cossie brad
Sep 29, 2015 02:38 PM
Mc5506
Sep 29, 2015 09:06 AM
sto6enc
Ford Mondeo Including ST
Sep 21, 2015 11:31 AM
Bransby
Sep 14, 2015 08:54 PM
