Brake master cylinder EAK!
Does anyone know if the strength of a brake master cylinder can be adjusted. I have done a seira rear disc conversion on my mk4 escort cabbie and just cant get the brakes right, after endless times of bleeding the system they are still crap. The servo and breake master cylinder are new, the sevo is a genuine ford part but the master cylinder a pattern part. I was told the cylinder may need adjusting to suit the setup. apparently there is a screw inside the flange where the cylinder ataches to the sevo.Has anyone herd of this?
The length of the push rod maybe adjustable yes, bit it wont affect any pressure.
Have you tried taking the caliper off to bleed it (ie so the bleed nipple is at the very top)
How are you bleeding them ? 2 man method ??
I have taken to calipers off and turned it so the bleed nipple is at the very top and have tryed the two man method and the E ZeeBleed many times but just can not get a good pedal?My friend has the same set up but he has used the origonal master cylinder and servo that was on the car and his brakes are awsom. Also he has just relied on the factory fit bias valves but i have a lockwood one aswell but its fully open,i cant see this affecting the front brakes aswell though??
May have to get a O.E Ford master cylinder and see if it makes a difference.
That rod inside the servo shouldnt really be played with tbh, it just holds the brakes on partially, which obviously isnt good.
When i first did my rear disc & 4 pot conversions they were crap but they do improve a lot when they bed in.
As Tony asked what brakes have you got all round and what size master cylinder?
I have got siera 2wd cossie calipers and discs on the rear and standard s2 turbo calipers and discs on the front
. its hard to tell which ones are not working they all seem crap. i tryed winding the wilwood biast valve shut to see if the fron calipers were doing there job but it didnt make the slighist bit of difference? also when the brakes start to work the pedal is almost past half way point before hitting the floor its all very odd?
The two rear ports on the master cylinder are teed into one line which then goes through the biast valve and tees off again into each caliper at the rear. I also jointed out the biast valve to see if it was faulty but made no difference
I also wondered if this was somthing to do with the problem,cos like i said my mate just changed the drums for calipers with the coversion bracets on his cabbie with out touching any thing else and his brakes work realy well.So he will still has the diagonal split?
Mmmmm, may be i will try re-piping them with the diaganal split and see if there is any improvement.May do away with the separate willwood bias valve as well see what happens?
I just picture the 2 oultets tee'd together and in theory it could be just pumping the air out of one outlet and striaght back in the other if you get me?
I'd say almost definately thats a contributing factor if not the only thing wrong
What size is your master cylinder?
Originally Posted by Robliddle
Just a standard s2 turbo one
Is that a cabriolet in your Avatar?
If so it's probably got a 22mm M/Cylinder which may explain your
current dilemma.
If unsure look on the side of Cylinder and it will have either 22, 23 or 25
Cast into it.
The 25 mm is the RST one.
Get one off any Mk4 Escort/Orion with ABS and you'll find it only has 2 outlets, that should solve your problem
