Correct or Not?
Old Apr 27, 2007 | 05:46 PM
BlueFiesta85's Avatar
BlueFiesta85
Default Correct or Not?
1) is this correct the two wires for the fuel pump (brown and red + black) the brown one is the ground and the red + black the live?
2) secondly i bought a fuel pump and took the old one off, the new one ive bought is longer then the original one, im guessing this will not fit into the bracket and is the wrong pump for the car (its a bosch one)
Old Apr 27, 2007 | 06:23 PM
Turbo-Beal's Avatar
Turbo-Beal
You are correct on the wires for the fuel pump. Black/red is the live feed from the fuel injection relay and the brown is the negative wire
As for the fuel pump you will need to get the numbers off it to find out what it is. Dont think the length will make any diffrece when fitting though.
Old Apr 27, 2007 | 06:27 PM
BlueFiesta85
just had a go with fitting the new pump up, its seems to catch on the bracket as the holes for the bolts dont align up correctly, guessing the pump is incorrect then, the pump is for a s1 & s2 turbo though dont understand why its longer then the original
Old Apr 27, 2007 | 06:35 PM
Turbo-Beal's Avatar
Turbo-Beal
Im guessing you have a standard fuel pump bracket? im not shure what they look like or how they are fixed as mine is a stainless aftermarket one which came with the car. Im pretty confident with one like mine the length wouldnt be a problem. Here is a pic of mine so you can see if its any diffrent?
Old Apr 27, 2007 | 06:38 PM
BlueFiesta85
i got my one from auto specilaists mate, its like the original one but made from stainless steel. just out of curiosity whats the length of that pump in the pic mate?
Old Apr 27, 2007 | 06:40 PM
Turbo-Beal's Avatar
Turbo-Beal
I havnt a cue m8 but i think the pump is off a subaru impreza so not standard.
Old Apr 28, 2007 | 04:28 PM
gambit's Avatar
gambit
Default fuel pump
it is the same pump as a cossie ask pj motorsport as they have these available off the shelf at a good price.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
OrionRST200bhp
Sep 29, 2015 08:30 PM
Fiddy
21
Sep 29, 2015 06:10 PM
RSmark84
Sep 13, 2015 01:29 PM
