anyone got any wiring diagrams pretty please?
Old Apr 27, 2007 | 02:45 PM
dojj's Avatar
dojj
Resident Wrestling Legend
Default anyone got any wiring diagrams pretty please?
as a follow on from my successful instalation of facelift dash to the mondeo (followed by my not so successful everything else not fitting because it doens't fit fisacso) i'm now on the hunt for both early and late spec wiring diagrams, cars from 00-03 and then 03-present
it's a ghia x so it's got the works other than traction control but the new switchgear i need to fit into the new fangled dash doesn't fit the old switches or plugs, to the extent that if i turn the ac on i get the sidelights coming on as well which flatened the battery the other night and if i press one of the bottons the hazards go on and don't turn off
so yes, basicly i'm after someone who car either supply me with a set of wiring diagrsms so i can switch switches or someone who can wire up the new controls to the new siwtchs using the old sirew
thank you
Old Apr 27, 2007 | 04:35 PM
o n i o n's Avatar
o n i o n
Have a look around here.
http://www.etis.ford.com/
Old Apr 27, 2007 | 04:45 PM
Eagle's Avatar
Eagle
Super Moderator
i think a gallon of petrol and a few matches might help you with your troubles mate
Old Apr 27, 2007 | 04:51 PM
o n i o n's Avatar
o n i o n
The 03 mondeo uses can wires to talk to all the other modules,
The instument cluster itself is a module, not sure if it would work properly?
Not that i'm a defeatest or anything.
Old Apr 27, 2007 | 05:49 PM
James's Avatar
James
As said, i doubt you'll get it working tbh without the right looms/modules.
i *may* have wiring diagrams, you on msn?
i think you'll find the switches simply send a signal, or a voltage pulse to a body control module which then operates the part.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
mk3ste
Oct 17, 2021 10:09 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
