M3 EVO WOUNT START
Old Apr 27, 2007 | 10:59 AM
STUCOS's Avatar
STUCOS
Default M3 EVO WOUNT START
Right folks,sold my m3 evo,ment to be going this weekend,had the battery off the past few weeks,put battery on,and know it wants me to punch a code in to the on board computre,to disarm the imobaliser,but i dont have a code,any body else had this problem
cheeRS stu
Old Apr 27, 2007 | 11:15 AM
Physio's Avatar
Physio
Go to bmw with your logbook etc & they should tell you what the code is providing it hasnt been changed after leaving the factory.
Old Apr 27, 2007 | 11:17 AM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
I guess BMW will want and hour labour for the privelege too
Old Apr 27, 2007 | 11:20 AM
Physio's Avatar
Physio
Quite possibly
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
I was half expecting a sarky comment from you!!
Something along the lines of
"This is a Ford forum, No ones answering you.. there BMW haters!!"
Old Apr 27, 2007 | 11:21 AM
STUCOS's Avatar
STUCOS
Thats the problem aj,it say,s in owners manual that you can change the code,to one of your own,and im betting some body has at some point
cheeRS stu
Old Apr 27, 2007 | 11:28 AM
Dan Cossie's Avatar
Dan Cossie
best thing is to at least try the dealer mate.........there must be a way round it
Old Apr 27, 2007 | 11:32 AM
Jim Galbally's Avatar
Jim Galbally
the dealer will be able to bypass it, it's the sort of thing you'd program in as a backdoor.
might need to get it AA'd to them tho
Old Apr 27, 2007 | 12:01 PM
WD Pro's Avatar
WD Pro
There is a (time consuming) back door but I cant remember it
It was expalined in the seven series owners handbook but I dont remember seing it in the three
If i remember correctly though the code is set every time you arm it so if it is armed now it is whatever you set it at to arm it.
Old Apr 27, 2007 | 12:10 PM
dojj's Avatar
dojj
Resident Wrestling Legend
how would you input the code then?
i remember jim pressing random bottons on his dash to make the needles go round so is it a combination that can be changed?
how many combinations are there?
etc
Old Apr 27, 2007 | 04:03 PM
WD Pro's Avatar
WD Pro
If the OBC is the full version with the key in position 1 you press ‘CODE’ followed by a number combination of your choice (using the number buttons used to set the clock - up to four characters I tink) then ‘CODE’ again then switch off. The red LED will remain lit indicating it is locked.
To disarm is the same process is followed. If you try to start without disarming the ignition will be dead, the ‘gong’ goes and the OBC just flashes up a warning.
You can use a different code every time you arm it if you want but it means you’ve got to remember it
Sounds like a ball ache but its actually dead easy and quick if you use a simple code that’s quick to enter.
WD
Old Apr 27, 2007 | 04:06 PM
ECU Monitor Enthusiast
BMW 0
COSSIE 1
Old Apr 27, 2007 | 04:08 PM
Mr Brannen's Avatar
Mr Brannen
I changed the battery on mine and it never asked for a code,OBC was fine
Old Apr 27, 2007 | 04:14 PM
WD Pro's Avatar
WD Pro
Nor on mine either if it is set its either been done inadvertently or there’s been an electronic glitch ...
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
xrmalin
Sep 13, 2015 06:52 PM
andrewmctiernan
Sep 8, 2015 03:05 PM
stevierob
Sep 7, 2015 07:09 PM
kevin36
Sep 2, 2015 06:24 PM
