low compression headgaskets?
Old Apr 25, 2007 | 07:35 PM
fast_ford_uk's Avatar
fast_ford_uk
Default low compression headgaskets?
have herd about them just wondering if they are any good, and whats the best type to get, im running 14psi, my heads been skimmed twice
thanks in advance
Old Apr 25, 2007 | 07:40 PM
T28 RST's Avatar
T28 RST
Ok then
Never heard of such an object
Old Apr 25, 2007 | 08:10 PM
fast_ford_uk
with a shim plate....what about the decomp plates you can get?
Old Apr 25, 2007 | 08:31 PM
T28 RST's Avatar
T28 RST
Ok then
De-comp plate
Old Apr 25, 2007 | 08:36 PM
fast_ford_uk
whats that suposed to mean?
Old Apr 25, 2007 | 09:06 PM
Chris69's Avatar
Chris69
decomp plates are not an ideal situation by any means mate, best bet is to source a new bare head and transfer all ur other parts
Old Apr 25, 2007 | 09:50 PM
ZVH,RST's Avatar
ZVH,RST
a spacer plate, to make it lower comp
Old Apr 25, 2007 | 10:00 PM
fast_ford_uk
lol i ment the 's
Old Apr 26, 2007 | 09:57 AM
ivorbiggun's Avatar
ivorbiggun
Just the job.........
I bought the last Felpro copper 'headsavers' (Felpro part No9309 sp1) when they ended production for the CVH.
I've got a couple left if you want one give me a yell.
Old Apr 26, 2007 | 12:55 PM
Red16's Avatar
Red16
i think fast_ford_uk means a thicker headgasket, not sure about the rs turbo's but on Evo's/Pulsar's etc you get the option of different thicknesses of headgaskets from the likes of HKS etc so if youre head has been skimmed or the block decked then you can keep the comp ratio as standard by fitting the thicker one.
Old Apr 26, 2007 | 07:35 PM
fast_ford_uk
as red16 said, my heads been skimmed so i want to run lower compression will these copper ones do?
Old Apr 27, 2007 | 12:16 AM
ivorbiggun's Avatar
ivorbiggun
Will lower it slightly depending on how much you've had skimmed I think they're .40 though thick will measure one in the morning.
Old Apr 28, 2007 | 05:27 PM
fast_ford_uk
ok i think i might try and get hold of a new head, just removed my wanked gasket and found very slight damage to my new piston were the inlet valves hit should be alrite tho. good old rs fund a..
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Fezman1
Oct 2, 2015 01:22 PM
Tank Mike
Sep 26, 2015 08:07 AM
