S1 Fuel Relay
Old Apr 25, 2007 | 06:19 PM
Stevie mix's Avatar
Stevie mix
Default S1 Fuel Relay
Went to start my car tonight and ther was no noise coming from the fuel pump and it wouln't start,so i tried the fuel relay in Series1 dry's car and it was the same,nothing,so i'd say its fooked
Can you still buy them new?
Item no V85 AB 9P7 04 BA
Old Apr 25, 2007 | 06:38 PM
SafeChav's Avatar
SafeChav
Don't assume!
Try the fooking fuse first
Old Apr 25, 2007 | 07:16 PM
s1rststeve's Avatar
s1rststeve
make sure thats what it is first as said but you can still get them,
i got one from my local ford dealer last year, about Ł45 if i remember rightly,
Old Apr 25, 2007 | 07:21 PM
Stevie mix's Avatar
Stevie mix
i checked them first,
The relay won't work on my car so tried it on Dry's car,which is running fine,and my relay is not working on his car...
So i'd say 99.9% the relay IS past it
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
SafeChav, are any of these relays useable on an escort with mfi?
http://www.partsandaccessories.com/s...ump_relay.html
http://www.autopartswarehouse.com/re...placement.html
Old Apr 25, 2007 | 07:29 PM
SafeChav's Avatar
SafeChav
s 1 ste, whip the relay out then and have a probe to see if you've lost any feeds to it or anything,
if its the relay i can almost guarantee its repairable!
vroooom ptssssh not that i can see but to be honest it doesnt give much specific information about them
Old Apr 25, 2007 | 07:40 PM
Stevie mix's Avatar
Stevie mix
[quote="SafeChav"]s 1 ste, whip the relay out then and have a probe to see if you've lost any feeds to it or anything,
Will do mate,nowt to loose if its goosed
The car's been parked in the garage since november last year,took it out the other week no prob's,wanted to move it tonight and nowt ...
Glad it happened now and not when i was away from home.
Cheers for ya advice SafeChav
Old Apr 25, 2007 | 07:44 PM
SafeChav's Avatar
SafeChav
Keep us posted on it, i doubt theres much wrong!
Which fuse did you check just out of interest?
Old Apr 25, 2007 | 07:58 PM
Stevie mix's Avatar
Stevie mix
Ididn't know which 1 it was, so i pulled each 1 out and checked,none of them had blown tho'
Old Apr 25, 2007 | 08:00 PM
SafeChav's Avatar
SafeChav
i'd check again cos ive had fuses which look fine at a glance but have had hair line fractures in them!
Its Fuse R1, theres only 2 fuses in the fusebox on there own, one is 15A, the other is 25A and its that one you want
Old Apr 25, 2007 | 08:15 PM
Stevie mix's Avatar
Stevie mix
i'll have a look tomorrow mate,thanks for that
Old Apr 25, 2007 | 08:38 PM
Wardy257's Avatar
Wardy257
You need a 5 pin tachometric relay. I bought one from Ford a few years ago for Ł8. I would do some volt drops first to confirm what is wrong though as it could be a fuse or wiring issue.
Old Apr 25, 2007 | 08:47 PM
Series1Dry's Avatar
Series1Dry
I doubt it is a fuse Steve cos mine won't start with your relay in it. I'm in town tomorrow if you want me to check at Pye Motors if they still do them
Old Apr 25, 2007 | 08:59 PM
Stevie mix's Avatar
Stevie mix
Sound Dry,
Been told it's still available from Ford ,item no 1630562, Ł35 + VAT,
Old Apr 25, 2007 | 09:10 PM
user 7082039239's Avatar
user 7082039239
Don't mention ze Vor
Or just open it and resolder the broken joints...
Old Apr 25, 2007 | 09:19 PM
SafeChav's Avatar
SafeChav
Ahhhhhhhhh i didnt realise that
they say great minds think alike
Old Apr 25, 2007 | 09:23 PM
user 7082039239
Old Apr 25, 2007 | 09:25 PM
SafeChav's Avatar
SafeChav
Its not en easy job but someone has to do it eh
Stevie mix's Avatar
Stevie mix
Had a look in side the relay all LOOKS fine,can't see any breaks in the solder/wires,but where do you start
SafeChav's Avatar
SafeChav
Multimeter perhaps?
Old Apr 25, 2007 | 09:41 PM
Stevie mix's Avatar
Stevie mix
I'll send it on to you SafeChav, you seem to know what your onabout i'm a bit with electrics
Old Apr 25, 2007 | 09:46 PM
SafeChav's Avatar
SafeChav
Ask dry hes a sparky isnt he
zzzzz zzzzzz
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
timsrs
Nov 13, 2018 11:48 AM
Brickhouse
14
Oct 3, 2015 07:28 PM
phil51
Ford Focus Diesel
Oct 2, 2015 01:00 PM
20/20 vision
Sep 29, 2015 11:27 AM
