2wd & 4wd header tanks!?
Old Sep 17, 2004 | 08:09 AM
B19-TRB's Avatar
B19-TRB
Default 2wd & 4wd header tanks!?
Whats the difference between the 2 header tanks!?
saff!
Old Sep 17, 2004 | 08:10 AM
cossiecrew's Avatar
cossiecrew
dunno but there different
Old Sep 17, 2004 | 08:11 AM
Matt's Avatar
Matt
water return spout location and bore
you have a 2wd bailey one on your new saph
Old Sep 17, 2004 | 08:12 AM
gurnE's Avatar
gurnE
4x4 has two returns
You can fit a 4x4 one to a 2wd car by blanking of the top one and using a 4x4 hose for the bottom
Alex has done this on his
kevin's Avatar
kevin
2wd has level sensor between inlet and out let tubes
also 2wd is unavailable...4wd has no level sensor
cheeRS
Old Sep 17, 2004 | 08:15 AM
B19-TRB's Avatar
B19-TRB
well basically i wanna uuder bonnet ot look standard as poss whihc means i wanna get rid of that baily tank Matt!
But the car runs a swirl pot whihc i will keep cause it serves a purpose! but obviously u need a 2md port for this!
spo if i used a 4wd tank i should b able to do so yes!?
& Lee do i just need to change the water hose!? or can u just get a stepper!? any1 know the ID of both pipes!?
Old Sep 17, 2004 | 08:16 AM
cossiecrew's Avatar
cossiecrew
standard? but why
Old Sep 17, 2004 | 08:21 AM
DOO's Avatar
DOO
Originally Posted by cossiecrew
standard? but why
Because he is pissed off cleaning shiny bits
Old Sep 17, 2004 | 08:23 AM
cossiecrew's Avatar
cossiecrew
dude you gotta have the bling
B19-TRB's Avatar
B19-TRB
cause shinny is
Old Sep 17, 2004 | 08:24 AM
Spiky's Avatar
Spiky
you cant run a std header tank and swirl pot
as you need 3 connection on header tank to do so.
Old Sep 17, 2004 | 08:25 AM
Matt's Avatar
Matt
od of 2wd water return spout is 7.88mm
od af 4*4 water return spout is 21.4mm
figures courtesy of dear old uncle tony
you'll have to get a 4*4 tank (only about Ł20 from ford) and then a T piece fitting kit and plumb into the existing water return from the turbo if you want to keep the swirl pot
theres been some class arguments about this being the wrong thing to do
ive run mine with and without a swirl pot and it makes no odds to anything as far as i can tell
Old Sep 17, 2004 | 08:26 AM
B19-TRB's Avatar
B19-TRB
Tone!
U got a 4wd tank & hose instock!? or even just the hose for now so I can measure it up!
Old Sep 17, 2004 | 08:27 AM
Matt's Avatar
Matt
or you could always just use the figures ive supplied
Old Sep 17, 2004 | 08:28 AM
Daveyraveygravy's Avatar
Daveyraveygravy
No, the Standard plastic 4x4 Header tank comes with only 2 'tubes.'
A lower one to supply the water and the higher one for the return.
It doesn't have a return for the swirl pot. You will also find that if you are running any more power than standard they will start to crack really easilly, and you risk it splitting
However i you could put a T peice into the return and keep your swirl pot, just a thought coz i've never seen it done?
Old Sep 17, 2004 | 08:29 AM
Spiky's Avatar
Spiky
the 4wd hose is 45 quid
Daveyraveygravy
I've got to learn to type faster!
B19-TRB's Avatar
B19-TRB
hhhmmm
so mayb loose the swirl pot all together then!?
if the 4wd tank has 2 outlets on top then surelty I dont have to t piece in2 it?
i think i need to look @ oth a 2wd & 4wd setup so i fully understand!
Will have a chat wiht Karl about swirl pot c what he says!
As if i buy timmys car this sat next sat its @ cars for a new chip & proper setup! let the spendin begin!
Old Sep 17, 2004 | 08:30 AM
AlexD's Avatar
AlexD
Post Miester !
I bought a 4wd header tank for mine and blocked off the bottom feed,
then bought two aero quip fittings and screwed and aradlited the into the top
where the usual feed goes on the 2wd tank, Works really well !....
Al......
Old Sep 17, 2004 | 08:32 AM
Spiky's Avatar
Spiky
using a t peice really isnt a good idea, as the temp of water coming from turbo it fooking hot
either use std header tank an NO swirl pot or keep the bailey tank
Old Sep 17, 2004 | 08:33 AM
Spiky's Avatar
Spiky
Al......
please dont take this as a dig.
but cant u gaurantee there is no air loos through the connections???
as it need to be air tight connections
B19-TRB's Avatar
B19-TRB
MR COSSIE 4X4,
thats the info i was after! so neither 4wd or 2wd tnaks have 2 returns! so basically its keep the bailey tank loose the swirl pot or t piece in!
cheers all!
any1 wanna buy a swirl pot!?
Old Sep 17, 2004 | 08:34 AM
cossiecrew's Avatar
cossiecrew
cause shinny is
you reckon. tidys it all up under there
Old Sep 17, 2004 | 08:35 AM
DOO's Avatar
DOO
Tone!
Showing stock mate
Old Sep 17, 2004 | 08:37 AM
Spiky's Avatar
Spiky
2wd header tank
4wd header tank
Old Sep 17, 2004 | 08:38 AM
SPADGE's Avatar
SPADGE
Or you could fook the cooling to the turbo off and use the top inlet on a std 2wd header tank for the swirl pot!
Old Sep 17, 2004 | 08:41 AM
B19-TRB's Avatar
B19-TRB
thats another option spadge man! but then thats not 3 good for the turbo is it!? T34!
spiky cheers m8 now i know where i am!
Old Sep 17, 2004 | 08:43 AM
SPADGE's Avatar
SPADGE
Why?
Old Sep 17, 2004 | 08:44 AM
Spiky's Avatar
Spiky
as a track car, spadge i'd aggree, but as a road car i think it would be best ot have the water cooling
due to the amount of miles it will do.
Old Sep 17, 2004 | 08:48 AM
User 32922's Avatar
User 32922
T Peice is fine mate....i use one, i did have a alloy one made up though
So i use a standard 2wd header with metal T Peice
Old Sep 17, 2004 | 08:49 AM
B19-TRB's Avatar
B19-TRB
well aint the turbo designed to be water cooled!?
this is a total road car!
Old Sep 17, 2004 | 08:53 AM
User 32922's Avatar
User 32922
Old Sep 17, 2004 | 08:56 AM
SPADGE's Avatar
SPADGE
Lewis and Spiky
Most engine builders/tuners recomend that you remove the water cooling from the turbo on tuned engines so if its ok on them then why not on a road car?
I havn't had water cooling on any of my engines since i bought the car 18 months ago and have had no problems!
Anyway its up to you its your car
Old Sep 17, 2004 | 09:02 AM
B19-TRB's Avatar
B19-TRB
furry muff spadge man!
I shall have a word with my tuner & c what he says on the situation! either way the header tank is goin!
Old Sep 17, 2004 | 09:06 AM
AlexD's Avatar
AlexD
Post Miester !
Al......
Yep i made sure they were sealed properly........ .. otherwise it would have been chucked in the bin..
Al...
Old Sep 17, 2004 | 09:07 AM
B19-TRB's Avatar
B19-TRB
Aint got it yet scotty!
Lookin @ Timmy's this sat!
Old Sep 17, 2004 | 09:20 AM
Spiky's Avatar
Spiky
nice one al
do one for lewi ten
Old Sep 17, 2004 | 10:03 AM
Matt's Avatar
Matt
theres a difference in the bearing housings between water cooled and oil cooled turbo's
do not remove it unless you really do know better than turbotechnics
