series 11 tick over adjustment help needed asap.....
Hi just need to know where the tick over adjuster screw is on a series 11 escort rs turbo......... thanks
http://img.photobucket.com/albums/v4...newpics002.jpg
Here's the filter set-up. The filter hole is covered with tape and behind that you have the fuel metering head. Inbetween those two is a small screw. That is for altering the air mixture.
Better pic of air adjustment part. You need to remove the screw and the adjuster is inside that. Think it's a flat blade also inside, can't remember 100%
http://i161.photobucket.com/albums/t...Picture055.jpg
jessie_rs
11
Jun 3, 2019 04:57 PM
kosienutter
31
Aug 22, 2015 09:55 AM
