Car battery Jumper packs, 12v
Old Apr 21, 2007 | 01:29 PM
Fiecos Dan's Avatar
Fiecos Dan
Default Car battery Jumper packs, 12v
Whats best?
And where from?
Up till now i've had a £40 jumper pack, but it dont hold the charge now,
so i'm looking to renew that, and buy a 240v one too.
Old Apr 21, 2007 | 02:18 PM
bigneck's Avatar
bigneck
i can quite honestly say ive tried / had them all, the cheaper 30 quid ones work kinda ok for a month or so but no real power, the sealy ones are slightly better and do last but forget starting most diesels especially if theres no batt power atall
nothing else works better than the snap on one, i bought mine a few months back for £180 1700 cranking amps it has started everything i wanted it to, i can honestly say if you use one quite often you simply cant buy anything else
Old Apr 21, 2007 | 02:23 PM
St3V3_C's Avatar
St3V3_C
You can buy new batteries for these cheap ones, depending on type about a tenner...
Examples here:
http://tlc-direct.co.uk/Main_Index/B...ies/index.html
Old Apr 21, 2007 | 02:33 PM
CabrioTurbo's Avatar
CabrioTurbo
i bought my dad a £80 one from halfords has a 240v inverter on it and to be fair to it its been damn good.
Old Apr 21, 2007 | 02:56 PM
Fiecos Dan's Avatar
Fiecos Dan
Cheers lads.
The £40 battery one i had, lasted 2 years, so might as well just try and replace the battery.
As for main's items, What sort of current do i need,
i have seen
120amp max booster for £55,
200amp for £94
400 amp for £118
Not sure what one i need, but i do need it to jump mainly tuned cossie's and RST's. even with flat batterys.
Old Apr 21, 2007 | 06:05 PM
St3V3_C's Avatar
St3V3_C
You probably want something in the middle mate - only really diesels / bigger engines need the bigger power ones.
Old Apr 21, 2007 | 11:10 PM
Fiecos Dan's Avatar
Fiecos Dan
Examples here:
i've got my jumper pack battery out,
and its alot bigger than the ones in your link. will they work the same?
my one is 12v, 17AH/20HR
Old Apr 22, 2007 | 06:15 AM
starturbo's Avatar
starturbo
i got one of those.cant fault it.
Old Apr 23, 2007 | 12:03 PM
St3V3_C's Avatar
St3V3_C
Examples here:
You will need to get something with the same Ah rating mate. Have a shop around
Old Apr 23, 2007 | 06:22 PM
Fiecos Dan's Avatar
Fiecos Dan
So it doesn't need to be the same pysical size to work the same if the Ah rating and volts are the same?
Old Apr 23, 2007 | 06:27 PM
Porkie's Avatar
Porkie
Renton got me one... its OF THE CHARTS!!!! its got built in power outlets and a wicked compressor and emergency lights and you can do it from terminals or cigarette lighter.
Its was around 100 sheets but is one of best things I have ever bought. Only ever charged it once 8 months ago... must have started 30 cars?!?!? and is STILL FULL!!!!
PM Renton.
Old Apr 23, 2007 | 06:40 PM
Fiecos Dan's Avatar
Fiecos Dan
Cheers Lee,
What make is it?
Old Apr 24, 2007 | 09:08 AM
Porkie's Avatar
Porkie
Its a blue one And the leads and read and black.....
Hope that helps
I repeat... PM Renton. Its the DADDY Just NEVER seems to run out of Juice and starts my Skyline and mates huge Jeep like they are Matchbox toys!
Old Apr 24, 2007 | 12:09 PM
bigneck's Avatar
bigneck
if anyone wants to buy one i have a brand new snap on booster pack the red 1700 amps, these are easily £200 from any snap on dealer, its a insurance replacement as i was burgled, brand new unopened best offer gets it
But i wont have it for a week as they have told me will take up to 7 days to arrive
http://www.portablepowerltd.com/port...erpack1700.htm
Old Apr 25, 2007 | 11:29 AM
SS1's Avatar
SS1
THERE SHITE ..i kept the receipt.and the box.. i know the first one was a godsend.about 8 flat tyres pumped up and jumped my old car about 4 times.
till it died after 7 months £80 would not hold the charge
exchange at shop n/p
second one wont hold a charge takes 4 days via the 12v power supply for 2 lights never goes to full charge
if you have the receipt ..the box..what more can they say.
ive got the 240volt option .but never used it.guess it would be piss poor looking at the ones i have bought
even so work this out
the charger has a safety feature which will not allow it to jump start a car unless it has 1.5 volts inside the battery..."the car not the charger SO does not that defeat the object in the first place "
i may ask for a refund this time ..as if you have a total flat battery your FUCKED anyway.. nice bit of kit that
Old Apr 25, 2007 | 05:21 PM
Fiecos Dan's Avatar
Fiecos Dan
Got hold of a 120a booster to test yesterday, (cost £100 ish)
Drained a battery to dead flat on my brother Pulser gtir, and tried it.
after less than a minute of booster charge, it started easierly,
so i disconected the king ht lead, and turned it over, and it was fine for that too.
So going to buy a 120 - 200 amp booster/starter from Machinemart for £60-80, matters what they have at the shop when i go there.
ar4ibaldo
Ford Focus ST
Aug 18, 2015 04:24 PM
track.focus'd
Aug 12, 2015 05:53 PM
tankybaby66
Aug 9, 2015 07:13 AM
xr_craig
Aug 7, 2015 06:00 PM
ricky
Jul 31, 2015 10:30 PM
