Alternator Wiring
Old Apr 21, 2007 | 11:30 AM
ProjectBobcat's Avatar
ProjectBobcat
Default Alternator Wiring
Hi, im using a 90amp alternator from a 4x4 saph cossie for a different application, the previous alternator i was using had 3 connections but the cossie one only has 2, the connections are marked as B+ and D+.
Am I right in thinking that the B+ goes to battery positive and the D+ goes to the small wire leading from the main car wiring loom (possibly the batteyr warning light?
Also as my battery is in the boot of my car could i connect the alternator-battery wire straight to the starter motor battery cable terminal.
Please help - Ross
Old Apr 21, 2007 | 03:54 PM
HI you guessed right!!
B+ is battery connection, D+ is after feild diodes and field current so goes to the warning light.
The connection you describe is fine to do, just make sure it has decent insulation, so it does not rub through anywhere as battery is powerfull enough to start fire if shorted.
I assume it is a BOSCH alternator from these symbols ?
Old Apr 21, 2007 | 04:52 PM
ProjectBobcat
Yes it is a Bosch alternator, you really know your stuff, thanks for your help
Old Apr 21, 2007 | 05:17 PM
I don't say a lot but when I do, it's usually crap ha ha.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
timsrs
22
Sep 24, 2015 08:14 PM
jay030787
Sep 18, 2015 04:38 PM
