anyone on here into PC Repairs?
Old Apr 20, 2007 | 06:51 PM
Gra's Avatar
Gra
Default anyone on here into PC Repairs?
I have a motherboard (mini ITX) i am building an in car PC, and i think i fried my mobo, but i dont know if its repairable, basically the board was working fine, XP was loaded, tested and working, i went to plug in a usb stick (but forgot i hadnt screwed the mobo down (there was a good reason for this lol) and it moved slighty and hasnt worked since, now and again it boots to post but oftern it gives an audiable warning. No parts are viasably fried etc, but i have changed the memory, removed battery, tried a PCI video card, (it has built in graphics) in the hop i would be lucky, but it dont work, shame tho but is it scrap?
Old Apr 20, 2007 | 06:56 PM
L33 BYT's Avatar
L33 BYT
Just try removing the BIOS battery and see if this resets the alarms.
If not you have fried it. Would proably not be visable.
Old Apr 20, 2007 | 07:08 PM
Gra's Avatar
Gra
i have done the battery thing, and it didnt reset the alarms,
Old Apr 20, 2007 | 07:23 PM
BigMouthBillyBass's Avatar
BigMouthBillyBass
sit it on a piece of cardboard (pizza boxes are especially good) and fire it up to make sure it's not shorting on anything underneath (assuming it is still sat in the metal case) If it's mounted badly two contacts may be shorting together
Old Apr 20, 2007 | 07:26 PM
Gra's Avatar
Gra
cheers mate, tried that already lol,
Old Apr 20, 2007 | 07:36 PM
BigMouthBillyBass
CHeck in the motherboard manual (if you havent got it, download a PDF version from the manufacturers website) and look at what the beep codes mean.
The beep codes vary depending on the fault, think sorta morse code e.g. long beep may mean memory fault, 3 short beep means processor fault etc etc, varies depending on the board
Give it a go, at least you may be able to figure out what is fried. Hopefully it wont be the processor, as thats usually the single most expensive thing to replace
Old Mar 19, 2008 | 01:12 PM
Turbocabbie's Avatar
Turbocabbie
Top Cab !!
im massive into the ITX scene, I run one in a mini-moto media centre, done in car systems using them along with MythTV and touch screens. Ive done volts mods to them and hard soldered additional USB along with other stuff
What model board is it ?... sounds like a 'M' series board probably a M1200
Am I right ?
Old Mar 19, 2008 | 01:15 PM
Turbocabbie
Top Cab !!
If the board follows the true ITX standard as laid out by Via and is not a ITX-FFB (ITX Form Factor Motherboard) the processor will be hard soldered to the motherboard and as such if the processor has gone in many cases the board, graphics, MPEG Decoder, 5.1 sound is lost along with the processor
Old Mar 19, 2008 | 01:46 PM
pani_k's Avatar
pani_k
PassionFORD Member
if its new/under warranty take it back to where you got it and play ignorant. my godbro is a system builder and got some static buildup on the board and half of it was dead. took it back and exchanged it.
Old Mar 25, 2008 | 08:27 AM
Turbocabbie
Top Cab !!
Originally Posted by pani_k
if its new/under warranty take it back to where you got it and play ignorant. my godbro is a system builder and got some static build up on the board and half of it was dead. took it back and exchanged it.
Sounds very nice and ethical, suggesting returning products you personally damage.. hope engine builders are taking note.
Old Mar 25, 2008 | 11:52 AM
FastFordChris's Avatar
FastFordChris
have you tried unplugging it from the mains hitting the power button a few times to clear any power left in the board then clearing CMOS, leave it for 10 mins then plug it back in and boot up.
tankybaby66
Feb 6, 2016 02:24 PM
gambo08
Feb 4, 2016 10:49 PM
rsguy
44
Sep 29, 2015 03:29 PM
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
