arp con rod bolts???
Old Apr 20, 2007 | 06:08 PM
garyrs's Avatar
garyrs
Default arp con rod bolts???
just a quick question , i am about to have new shells and uprated bolts fitted , the thing is i have seen a lot of posts asking what tourqe setting they have?? so i take it there diff from standard. does it not say on the packet or what? also the crank isnt bein reground as this engine is just temp while the other 1 is being repaired, will i need to run them in , or can i just drive as normal? cheers gary
Old Apr 20, 2007 | 06:12 PM
If ARP do not give alternative torque they must be the same.
I would just take it easy for a few miles(500ish) without letting the engine labour at all.
Old Apr 20, 2007 | 06:17 PM
garyrs's Avatar
garyrs
hi tabetha , i havent bought them yet so i dont no if it states on the pack, i have seen quite a few posts that wat to no what the tourqe settings are , do you think that the 500 miles of easy drivein will be ok with current set up , or should i turn boost down? cheers for the reply, gary
Old Apr 20, 2007 | 06:30 PM
Moonstone Mart's Avatar
Moonstone Mart
Garyrs,
The ARP con rod bolt i bought had fitting instructions supplied with them.
You apply the grease and work through a tightening/loosening sequence
Nice and easy to follow.
Mart
Old Apr 20, 2007 | 06:36 PM
garyrs's Avatar
garyrs
cheers mart, its goin to the engineers any way but he useally does standanrd stuff so just wanted to chek , gary
Old Apr 20, 2007 | 08:47 PM
500 miles plenty as it is just a shell change, would not even bother to change the oil until regular interval.
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
stevecfrst1
Sep 30, 2015 05:18 AM
DavidK
Sep 27, 2015 02:55 PM
little bram
Sep 27, 2015 07:45 AM
