FAO - people with secs monitors
Old Apr 19, 2007 | 07:48 PM
M K's Avatar
M K
Default FAO - people with secs monitors
just bought 1 of these of mike r today cheers mate which will be turning up tommorow and im hoping to fit it before pod on sunday,
i can solder ok but is it tricky to do and were do they to wire in? i take it i will have to take the boot off the hairbrush multiplug for the ecu then solder in there
anybody have pics of were/how they wired theres in please
i dont want to cock it up as my loom cost me about £450
Old Apr 19, 2007 | 07:53 PM
warleydaddy's Avatar
warleydaddy
I dont know,as i let Sean B do mine while i had a KFC and a fag...
But if you have got it new,you will get ALL fitting instructions,,And there very clear,and aeasy to read/use..
Pete..
Old Apr 19, 2007 | 07:57 PM
ECU Monitor Enthusiast
Its easy to do if you can solder.
Just pop out the pins required one at a time using a paper clip end in the
side of the pin from the ecu connector side while firmly pulling the wire
behind. (Not so hard as to break the wire)
Then solder the wire to the back of the pin and pop it back in.
Old Apr 19, 2007 | 08:01 PM
Tev's Avatar
Tev
i just sent my sec monitor loom off 2 Ryan 2 b added 2 my new loom after i looked at the instructions, lol it dont look 2 hard but at the end of the day i wouldnt wanna fuck it up,
Old Apr 19, 2007 | 08:02 PM
gus's Avatar
gus
or you could have a loom with a plug thats already in the loom
Old Apr 19, 2007 | 08:32 PM
M K's Avatar
M K
cheers people,
simon - thats the exact info i was after, least i now know i can pop the actual pins out and solder to the pin itself rather than splicing in to each wire
if mine weren't already in the car mate i would swap ya but i aint taking all mine out again
not unless its to replace it with F88 anyway
Old Apr 19, 2007 | 09:14 PM
abdr500's Avatar
abdr500
Electronic
would there be a problem if you was just splice into the wire and do it
Old Apr 19, 2007 | 09:16 PM
Originally Posted by abdr500
Electronic
No problem at all as long as the joint is properly made and soldered
Old Apr 19, 2007 | 09:21 PM
abdr500's Avatar
abdr500
Electronic
Old Apr 21, 2007 | 09:59 PM
M K's Avatar
M K
all fitted now
the pins were a fooker to get out of the hairbrush plug tho
nobody mentioned to me it doesn't read the rpm correctly tho for coilpack users, bit dissapointed at that realy
any solution anytime soon on that issue?
Old Apr 21, 2007 | 10:32 PM
Jasesapphy's Avatar
Jasesapphy
there is a thread on here at the mo, have a serach
mk3ste
Oct 17, 2021 10:09 AM
Rsmat
89
Oct 12, 2015 07:50 AM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
rsguy
44
Sep 29, 2015 03:29 PM
pabloXR
Sep 21, 2015 12:42 PM
