is it normal for a cossie breather to spit oil out on boost
Old Apr 19, 2007 | 07:14 PM
Roosie's Avatar
Roosie
500bhp Cosworth in making
Default is it normal for a cossie breather to spit oil out on boost
i havent got no hose that goes to my airfilter to turbo yet so the airfilter is bolted thgere as it has the std breather outlet going into it when i was botingit up the road and come back i had a little oil coming out the filter as abvoiusly its coming out breather or would it be different if i had the turbo all connected to filter with a hose?
Old Apr 19, 2007 | 07:59 PM
Best thing to do with your is to get a breather on it, and do away with the PCV one on it at the moment, use catch tank or drain down to offside block for return.
Old Apr 19, 2007 | 08:03 PM
Rick's Avatar
Rick
Yes mate, the way you have it it is normal. As long as there's not gallons of the stuff.
Old Apr 19, 2007 | 08:05 PM
col cos1's Avatar
col cos1
as above bailey breather
Old Apr 19, 2007 | 08:20 PM
*Bri.4.b.Cos*'s Avatar
*Bri.4.b.Cos*
Or if you don't like bling, Fosters can and a bit of pipe
Bri.
Old Apr 19, 2007 | 08:29 PM
Roosie's Avatar
Roosie
whats better catch tank or drain back in car
Old Apr 19, 2007 | 08:34 PM
*Bri.4.b.Cos*
Drain back into engine will not require emptying, catch tank will
Bri.
Old Apr 19, 2007 | 09:13 PM
Roosie's Avatar
Roosie
how much am i looking at for a breather with hoses ect if i want to take it back to engine?
also do i need to put a adapter in rocker cover?
mint_s2
Sep 2, 2015 08:58 AM
YODI
Aug 30, 2015 01:12 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
JoeyBoyden
Aug 18, 2015 10:52 PM
RsS2daz
Aug 14, 2015 05:26 AM
