Blue smoke!!!!
Old Apr 19, 2007 | 05:30 PM
OrionRST200bhp's Avatar
OrionRST200bhp
Default Blue smoke!!!!
what are the likely cause's of it?? my mate was following me today and he said when i nailed it he said it was puffing out blue smoke not alot just a mist. got the missus to drive it up the road and every time she changed gear it would puff a little bit out. should i be worried. im just about to rebuild the head. i dont really want to splash out any more cash on it.
Old Apr 19, 2007 | 05:36 PM
Physio's Avatar
Physio
Could be a number of things, inc turbo oil seal, stem seals, over filled oil level??
Old Apr 19, 2007 | 05:52 PM
xr_craig's Avatar
xr_craig
As above mate, could be any number of things, i'd be inclined to think turbo oil seals though
Old Apr 19, 2007 | 05:54 PM
DaveyBoyS1's Avatar
DaveyBoyS1
If its smoking under acceleration could be worn piston rings or blocked breather... or any of above. Get it looked at.
EDIT: If its on gear change... likely to be turbo seals.
Old Apr 19, 2007 | 05:55 PM
col cos1's Avatar
col cos1
shagged turbo
Old Apr 19, 2007 | 06:01 PM
OrionRST200bhp
the turbo is fairly new from what the previous owner said it is only a standard t3 turbo though is there any way i could check these things my self? as the closest decent cossie tuner is in plymouth which is roughly 2 hours driving from me.
Old Apr 19, 2007 | 08:11 PM
col cos1's Avatar
col cos1
you couldnt check turbo seals easily but take the pipe off turbo to filter,and check for play in the shaft/wheel,a little side to side is ok but defo no in and out
Old Apr 19, 2007 | 09:23 PM
abdr500's Avatar
abdr500
valve guides in the head can cause this
Old Apr 19, 2007 | 11:12 PM
Carlsworth's Avatar
Carlsworth
Former Sponsor
if you find it to be the turbo, it can be reconditioned, and back on your car within 5 days
you just need to know someone who can provide such a good service with 6 months warranty on all serviceable parts, and at a shockingly afforadable price
pm me for details....
Old Apr 19, 2007 | 11:15 PM
xr4x4rs's Avatar
xr4x4rs
mine did this and was worn valve guides my turbo was new aswell
if you rrebuilding the head then check the valve guides and proberbly worth replacing them anyhow with some new bronze ones
Steve Escos
Oct 1, 2015 06:57 AM
DAZZER
Sep 30, 2015 08:43 PM
