what ecu chip?
Old Apr 19, 2007 | 05:18 PM
juffer's Avatar
juffer
Default what ecu chip?
i have got a chipped ecu and would like to know what chip it is. the ecu is blue red black on the outside case. then there is a little metal cover over the chip with a picture of a "diamond" and a letter "t". on the chip it has got a sticker with "dt" on it. any ideas????? ta
Old Apr 19, 2007 | 05:27 PM
ECU Monitor Enthusiast
What colour is the chip itself ??
Is it black, brown or dark purple ?
Old Apr 19, 2007 | 05:29 PM
juffer's Avatar
juffer
its black motorola.
Old Apr 19, 2007 | 05:30 PM
99% sure thats NOT chipped - Its standard
Old Apr 19, 2007 | 05:32 PM
juffer's Avatar
juffer
i put it back to geather and that was a guess from memory.it is a different colour from the rest. what are the other colors?
Old Apr 19, 2007 | 05:36 PM
The updated chips are usually brown or dark purple and also have a
window on them which is hidden by the heatsink alluminium strip.
juffer's Avatar
juffer
i have just had it apart and it is brown. what is it? ta
Old Apr 19, 2007 | 05:40 PM
Brown - Its chipped.
All updated chips are nearly the same no matter what spec as the boost
limit has been removed and the ignition timing is adjustable on the dizzi.
Old Apr 19, 2007 | 05:46 PM
juffer's Avatar
juffer
cheers mate.
Old Apr 19, 2007 | 05:57 PM
Stu @ M Developments's Avatar
PassionFords Creator
DT is the old superchips name.
Detection Techniques.
Old Apr 19, 2007 | 05:59 PM
ZVH,RST's Avatar
ZVH,RST
is it a rs turbo.??? if so i bet it is a early superchipped so yes it is chipped,
Old Apr 19, 2007 | 06:16 PM
juffer's Avatar
juffer
yes mat rs turbo
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
tankybaby66
Feb 6, 2016 02:24 PM
griffo69
Oct 4, 2015 11:58 AM
RSmark84
Sep 13, 2015 01:29 PM
