4x4 cosworth oil return pipes on there turbo
Old Apr 18, 2007 | 09:22 PM
Roosie's Avatar
Roosie
500bhp Cosworth in making
Default 4x4 cosworth oil return pipes on there turbo
my t35 turbo return pipe rest against turbo manifold slightly so i cant tighten it right up wonder why my car was smoking from turbo area does anyone elses sit this close or on the manifolk
Old Apr 19, 2007 | 06:36 AM
BEND it then!!
Old Apr 19, 2007 | 06:42 AM
Roosie's Avatar
Roosie
my luck it will snap
Old Apr 19, 2007 | 07:09 AM
Kevin B's Avatar
Kevin B
Mine dont sit that close / touch manifold mate...
Old Apr 19, 2007 | 07:15 AM
Roosie's Avatar
Roosie
i think i might have to twist the front housing a little may help
Old Apr 19, 2007 | 12:33 PM
I'll bend it for you then, or remake, cut reweld etc whatever.
Old Apr 19, 2007 | 12:36 PM
Roosie's Avatar
Roosie
sorted now i turned the housing. cheers
dont fancy doing my lambda plug for me in my exhaust?
Old Apr 19, 2007 | 12:38 PM
Turbosystems's Avatar
Turbosystems
Super Moderator
your turbo core assembly has been incorrectly orientated you need to realine the core on the exhaust turbine housing then realine the compressor
Old Apr 19, 2007 | 12:39 PM
Roosie's Avatar
Roosie
ive done it now mate its cos i had a 2wd t34 and had to change it for 4wd so just had to do a slight adjustment
Old Apr 19, 2007 | 05:59 PM
YES I will be more than happy to weld in your boss for lamda for you!!
big_Rad
Sep 15, 2017 09:36 AM
Bailes1992
Aug 16, 2015 07:14 PM
cossie4x4
Aug 14, 2015 06:29 PM
Aug 14, 2015 07:29 AM
Old ford
Jul 31, 2015 06:50 AM
