bleeding brakes
Old Apr 18, 2007 | 09:11 PM
raggey's Avatar
raggey
Default bleeding brakes
Hi chaps
I have fitted a cossy brake servo to my kit car, when I go through the cossy work shop manual to bleed the brakes at first it bleeds ok but then the pedel goes hard on the passangers side even when the bleed nipple is open. When you check all the brakes you can"t turn any of the wheels but the passanger side spins freely. I have chaned the caliper changed the pipe work still no change. any ideas
Paul.
Old Apr 18, 2007 | 09:26 PM
NUTS RuS's Avatar
NUTS RuS
Ignition on during bleed process ?
Old Apr 18, 2007 | 09:31 PM
raggey's Avatar
raggey
not when bleeding fronts as it only tells you to but ignition on when doing the backs is this wrong
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
