FRST- jerking on WOT
Righty then, back to this problem yet again
car is 1.8 efi zvh, chip, cam bla bla bla!!!
The problem is that when you floor it, the car will suddenly cut the ignition- almost as if its hitting the overboost, and from then on will continue to do so if you floor it.
However, if you are nice and progressive on the throttle, then its fine, and will boost as per normal....
I say back to this prob again, as it happened last year, and it turned out that i had received an xr2i ACT rather than a frst ACT, and that was causing the problem, buit this has been changed, and been good as gold until about a week ago!
Does it sound like the map sensor is fubar, so a new one would solve it?- and if thats the case how much am i looking for a 3 bar jobbie ? (as the management is OFAB).
Finally, i am right in thinking it is a straight swap, yeah????
Cheers for your help on my shonky lego like engine!
dont just replace the map sensor rich, test it first... it takes MINUTES with a multimeter. tell you what, i'll help ya disgnose the fault if you help me adjust my coilovers later
boost hoses are all 1 year old samco's matey- and i really don't think standard boost will close them
- ill check them though, just to be sure!, cheers!
Jim- no worries chap- pop round later!
rich its cause the engine wants ya to turn the boost up mate, its bored
if ya wanna test the map sensor i got a brand new one ya can test
oh and if ya look in the traders section theres a guy selling em for 70 quid delivered
aj- no worries chap!
ginge- cheers, ill keep that in mind! And as for the boost, i can't turn it up if the car is jerking like a bastid can i
lol! - should be quite nippy on a bar though!
Also, just been out to take the g/f to work, on the brakes, it boosts fine in second, no jerking, do it in 3rd, hit about 6 psi, and it jerks, then it will do it everytime you floor it, and it hits about 3 psi
anyone got a suggestion?
Cheers peeps!
edit as ive just seen nicks reply- cheers, ill clean up the plugs, and see if that sortes it- they are about a year old i spose!
Cheers peeps!
depends rich... in 1st it doesnt have anywhere near as much load on it...
0-5 is the norm... mine's 1v - 4.5v on the 24v
wouldnt worry too much about the values, just make sure its smooth n doesnt have flat spots
TPS, CTS, ACT, MAP are all easy to test with a multimeter
ive got all the data here n i'll pop it over later... you workin 2nite?
rich, i'll pop over and bring autodata so we can load it onto your PC (save me printing everything out) its got SHITLOADS of detail on the FRST
i'll bell you when i know a time, as i may even be out of work early!!!
rolls whats the diff in the act sensor again??
you sure its not fouling the plugs or something? as you on beiges arent you??
maybe it kinda floods?
oh and autodata jim??? you going nat day? does it copy?
my old frst engine did this
a couple of weeks after it started doing it, it ran lean on the motorway and dropped the spark plug electrode through the piston mashing 2 valves and ruining the block and head.
when i fitted my new engine i used the exact same sensors inlet ecu etc and it did not do it but i had it set up
has your car been setup ?
if it was done by BSW maybe you should get it looked at again matey
yeah, as per jim its been set-up, and it is mr Butchers old zvh!
looks like ill have a look over it with jimbo before comming to any conclusions!- im sure the data that he's got could come in handy!
roll get dingy to make you a new cossie loom and fit it
i so wanna see the ickle fezzy with the "plan"
but fit wider seats as "normal" sized people cant fit in em ( no im not fat, i am big boned
rich, you dont need an EECIV version of secs... simply chop up the multiplug and make it fit the cossie connector
i'm sure the ECU is clever enough to understand and interpret the signals it gets from the FRST sensors
also remember rich that all the wiring wiggling etc. etc. that was done coulda helped
also TPS on your TPS i stripped off about a 1mm section of wire thats now exposed when i was using the multimeter, and i havent put any tape over it... it cant hurt to cover this up when you get a sec mate... its the brown wire closest to the front of the car
yeah, i know about the wire chap- cheers
Ginge, as for the seat- not a chance!- its great round corners being able to feel exactly what the car is doing
and i wana wait till the eeciv is rrealeased, as i don't wana have to chop up my loom.......................again!
passenger is still a recaro, and will prob stay that way, as my bro is 6"9, and 18 stone, so a bucket is a no-no, when you comapre at other times, some of my mates are 8 stone, and about 5" tall
- they'd get dwarfed by a bucket made for Ian!
