Amal valve and chip
Old Apr 16, 2007 | 02:23 PM
Rabbit's Avatar
Rabbit
Default Amal valve and chip
Allright, I got a 330hp chip from ahmed bayjoo and i was wondering what do do with the amal valve. Is the chip programmed to use it or can i simply remove it and install my electronic boost controller??
Old Apr 16, 2007 | 06:28 PM
reisskahn's Avatar
reisskahn
Rabbit thats a good question and i was thinking the same when i installed mine. Ive got the same chip on a stage 3 conversion and a Blitz SBC-id 3 boost controller. Ive jst disconnected the amal valve althoghter but am not too sure if thats a good idea.
Best to see what other ppl think
Also what controller are you planning to use?
Old Apr 16, 2007 | 06:49 PM
Rabbit's Avatar
Rabbit
I belive that the chip doesent care about the amal valve and doesent use this to control the boost pressure, unless its programmed to. I don`t know if the bayjoo chip is programmed to use it or not
Ive got a Blitz Dual SBC Spec-R boost controller...
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
