help needed with dump valve
Old Sep 15, 2004 | 09:37 PM
jonesymk2's Avatar
jonesymk2
Default help needed with dump valve
ive got a bailey dump valve on my s2 erst,the other day
i drove it to my mates to do a bit of work on it and the
dump valve worked fine,took my car to my mates again
tonight and the dump valve didnt work,anybody got any ideas
Old Sep 15, 2004 | 09:38 PM
Phil's Avatar
Phil
Jeebus
Seeing as you're from Luton it's probably been nicked
Old Sep 15, 2004 | 09:39 PM
SPADGE's Avatar
SPADGE
On a serious note check no pipes have fallen off!
Old Sep 15, 2004 | 09:40 PM
Physio's Avatar
Physio
Have you checked the seal inside?
Old Sep 15, 2004 | 09:42 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
best advice, take it off as its prob leaking, what type is it?
jonesymk2's Avatar
jonesymk2
did check to see if it had gone but luckily it was still there
the car still pulled as well as it did the other day when the
turbo came in,checked the pipes quickly as it was dark but
all looked fine
Old Sep 15, 2004 | 09:43 PM
jonesymk2's Avatar
jonesymk2
its a piston type
Old Sep 15, 2004 | 09:46 PM
vroooom ptssssh
It Wasnt Me!
hmm, maybe its jammed, weird one, best takin it off n havin a look to see if u can move it with a screw driver or summik, best takin it off all together tbh. their jus problematic.
Old Sep 15, 2004 | 09:50 PM
jonesymk2's Avatar
jonesymk2
car was running a bit crap when i drove it round to my mates
house,it almost cut out a few times when i stopped at
road junctions,would this hav anything to do with the dump
valve do you reckon
Old Sep 15, 2004 | 09:53 PM
vroooom ptssssh
It Wasnt Me!
possibly if its jammed open it'll be measuring un metered air causing it to stall.
Old Sep 15, 2004 | 09:55 PM
EIL132's Avatar
EIL132
It trying to tell you to throw it in the bin
Old Sep 15, 2004 | 09:56 PM
Lee Reynolds's Avatar
Lee Reynolds
vacuum pipe off?
Old Sep 15, 2004 | 09:57 PM
jonesymk2's Avatar
jonesymk2
no its still shut,how easy will it be to move the piston
to make sure it aint jammed,what difference will it make
if i take it off if any atall
Old Sep 15, 2004 | 09:59 PM
jonesymk2's Avatar
jonesymk2
the pipe from it to the inlet manifold is still on and the
boost gauge is still working and couldnt see any other
pipes off
Old Sep 15, 2004 | 10:36 PM
vroooom ptssssh
It Wasnt Me!
if u take it off u can check if all's moving freely.....is the piston open or closed on idle?
Old Sep 16, 2004 | 03:55 PM
jonesymk2's Avatar
jonesymk2
i think the piston was closed on idle
Old Sep 16, 2004 | 03:58 PM
cossiecrew's Avatar
cossiecrew
sounds fuct just bin it and buy a new one
Old Sep 16, 2004 | 04:01 PM
jonesymk2's Avatar
jonesymk2
it was working fine on saturday,hadnt used it since then
till last night and then it werent working
Old Sep 16, 2004 | 04:18 PM
Stu @ M Developments's Avatar
PassionFords Creator
You cant use a single piston on an Esc RST anyway pal.
Old Sep 16, 2004 | 04:26 PM
jonesymk2's Avatar
jonesymk2
it was fitted on the car when i got it,why cant i use it on my car then
Old Sep 16, 2004 | 04:39 PM
jonesymk2's Avatar
jonesymk2
can anyone put a couple of pics up just to make sure im not getting
mixed up with another type of dumpvalve
Old Sep 16, 2004 | 05:28 PM
ballin's Avatar
ballin
just rev it with the bonnet up and see if it opens and closes, then you'll know if its stuck!
Old Sep 16, 2004 | 05:36 PM
Daveyraveygravy's Avatar
Daveyraveygravy
Am i right in saying RST don't come with a D/V as standard?
Old Sep 16, 2004 | 06:02 PM
ballin's Avatar
ballin
you are indeed
Old Sep 16, 2004 | 06:25 PM
jonesymk2's Avatar
jonesymk2
brought the car back from my mates house today,when i got
there i lifted the bonnet while the car was idling and the dump
valve was closed,then i had to turn the car off and about 5 minutes
later i started it up again and the dump valve was open and
when i drove the car home i took a little detour and it is working
again now
shortie
Aug 19, 2015 01:01 AM
rsstav
Ford Focus RS Parts for Sale.
Aug 16, 2015 08:38 AM
Churtz
15
Aug 13, 2015 06:40 PM
rsstav
Aug 11, 2015 04:22 AM
col93saphcos
Aug 7, 2015 03:21 PM
