Why has my rs got a deadspot/miss fire high rev and load?
Old Sep 15, 2004 | 06:31 PM
L33 BYT's Avatar
L33 BYT
Default Why has my rs got a deadspot/miss fire high rev and load?
Changed dissy cap rotor and plugs but giving like an over boost effect at high revs however also under load.
Also checked Timing and is 12 Degrees BTDC.
Had new Grp A Head gasket few weeks ago and head checked and skimmed.
Any ideas on this one?
Old Sep 15, 2004 | 07:25 PM
L33 BYT's Avatar
L33 BYT
Any ideas people? Please
Old Sep 15, 2004 | 08:17 PM
Rick's Avatar
Rick
more info - spec, when it happens, what does boost gague do etc.
Old Sep 15, 2004 | 08:18 PM
cossiecrew's Avatar
cossiecrew
get it set up by an expert
Old Sep 15, 2004 | 09:14 PM
L33 BYT's Avatar
L33 BYT
Cossiecrew, to be honest plan is too. But i'd at least like to have her running half decent before it goes any where.
In regards to spec.
Exhaust and filter only guys.
Old Sep 15, 2004 | 09:17 PM
L33 BYT's Avatar
L33 BYT
Rick i'd say a little hard to explain to be honest. She has had the amal valve D/C'ed may connect that back up tomorrow .
Old Sep 16, 2004 | 11:38 AM
L33 BYT's Avatar
L33 BYT
Right ok
1 - 3 psi
2 - 9 psi
3 - 9 psi
4 - 9 psi
Fuming is an understatement. Just had the head put back on.
Was skimmed, torque down correctly, pressure tested. Valves were not removed when the company skimmed head.
Can my Felpro be re used as it has only done 50 miles or so or would you say new gasket.
It can only be a valve problem?
boeb
Jan 9, 2020 05:11 AM
tankybaby66
Feb 6, 2016 02:24 PM
