series 2 Fuel relay
you will more than likley find that some under knoledged idiot has pulled a 12v supply directly to the pump, have a check under the rear seat, thats normally a popular place that I have seen attacked, otherwise, the fuel pumps supply wire is a black wire with a red trace that runs along the sill towards the back of the car and goes through the floorpan under the rear seat via a rubber grommet. unscrew the plastic interior trim that runs along the sill and have a check for signs of halfords style of repairs/wiring, when you find it, I suggest ou solder it back together and heat shrink it/ or what ever the damage is and obtain the correct fuel pump realy. there really is no reason for shit wiring! drives me nuts!!
hope you can solve your problem!
Originally Posted by PeteS2RST
yes it a S2 The clues in the title (sp)
As said have a check for splicing into the wiring, you'll have to hope its been done somewhere thats obvious/easy to get to.
when you take the relay out aswell?
