Alternator Q ?
Old Apr 12, 2007 | 08:52 AM
Scott-rs2k's Avatar
Scott-rs2k
Default Alternator Q ?
hi guys
alternators packed up on a 1.8 xr3i 130ps
been offered for free a good workin order 1.6 fiesta zetec alternator
ok same engine but are they the same alternators throughout ?
cheers
Old Apr 12, 2007 | 10:55 AM
SafeChav's Avatar
SafeChav
All you need to check is the charging rate of the alternator, probably 70A at a guess, should be a sticker on there with the rating
Old Apr 12, 2007 | 05:00 PM
If it fits it will work if ok, use it.
Old Apr 12, 2007 | 08:26 PM
Wardy257's Avatar
Wardy257
It depends if the Fiesta as of a similar age. At some point Ford changed it all so the ECU managed the charging rate so it is not always simple.
Old Apr 12, 2007 | 11:04 PM
SafeChav's Avatar
SafeChav
Really?
So the ECU handles 70 odd Amps of charging current to the battery
Old Apr 13, 2007 | 07:46 PM
Wardy257's Avatar
Wardy257
Really?
No, the ECU will stop the alternator charging in certain conditions.
This sort of thing is going to get worse as the EU want to reduce engine idle speeds lower and lower because of emissions.
Old Apr 16, 2007 | 06:50 AM
Scott-rs2k's Avatar
Scott-rs2k
ok confused, lol i thought an alternator is an alternator and can only charge with the belt etc
the alternator i got to put on is a m plate fiesta 1.6 si one and the car in question is a 130 ps xr3i 16v zetec 1.8 ?
yet to be taken of the car to check if there the same size etc yet ? or any difference
Old Apr 16, 2007 | 11:07 AM
SafeChav's Avatar
SafeChav
Ignore the comment about the ecu controlling the charge thats not relevant to a car as old as yours.
As i said above check the current rating of the unit, even if it fits it will stil work but its best to have one of the same rating ideally, if its lower it may struggle when you load it up.
jonfoc
16
Sep 11, 2018 05:35 PM
steve.rst
Mar 15, 2016 08:01 AM
timsrs
22
Sep 24, 2015 08:14 PM
jay030787
Sep 18, 2015 04:38 PM
benw456
Sep 16, 2015 05:27 PM
