turbo chatter
Old Apr 11, 2007 | 12:06 AM
cossied's Avatar
cossied
Default turbo chatter
After an engine rebuild and a new actuator no problems for 7000 miles now i can here chattering when I lift off also a rattle that sound like a baffle has worked loose in the exhaust anyone have any ideas, thanks
Old Apr 11, 2007 | 12:23 PM
RickyLee53's Avatar
RickyLee53
Default Re: turbo chatter
Have you got a dump valve fitted?
Old Apr 11, 2007 | 01:31 PM
cozmeister's Avatar
cozmeister
More boost Igor!
If there's more boost than the dump valve can dump, you'll get a little bit of chatter - assuming you have a dump valve I get a bit on mine, even with an atmos. dv on
Old Apr 11, 2007 | 03:54 PM
cossied's Avatar
cossied
Default chatter
Yes I have a group A dump valve. I can hear it dumping and chattering at the same time. Thanks
Old Apr 11, 2007 | 05:55 PM
cossied's Avatar
cossied
Default chatter
Just been out in it and it is overboosting,any thoughts, thanks
Old Apr 13, 2007 | 10:29 PM
granth's Avatar
granth
Just don't lift.
But really, if it's overboosting and just had engine rebuilt, check your vacuum lines to the wastegate and make sure there hooked up properly and not leaking.
Edit to add:
Uh, just reread that 4000 and was okay. If new problem that was not there for the first 4K, it may be a bad wastegate actuator. Or already gone bad. But start with the easy.
JK12
33
Apr 26, 2021 12:09 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
