Longer 5th gear
Old Apr 6, 2007 | 09:29 PM
wilmot's Avatar
wilmot
Default Longer 5th gear
Read somewhere that someone has fitted longer 4th and 5th gears into there Cossy Box..............I understand this will help on a run....does anyone have any views on this and who carried out this modification...sounds like a good idea for 5th, but not sure about 4th.. Thanks 'Wilmot' (Liege-Belgium)
Old Apr 7, 2007 | 07:43 AM
This would entail a complete input and output shaft change.
It is possible to use different gears if they exist, like for the US spec box.
Having looked through the TTC book, I can see none listed.
Old Apr 8, 2007 | 03:31 PM
wilmot's Avatar
wilmot
Just had this sent to me................ will it take the extra power...........any views........http://www.maddoldbugger.supanet.com/
Old Apr 8, 2007 | 09:56 PM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
looks like it's easily possible... will have to think about doing this when i break my mt75
Old Apr 8, 2007 | 10:26 PM
wilmot's Avatar
wilmot
I have this subject on Ford-Force and Viper replied....4th I'm not sure about, but on the MT75 the standard 5th gear is 0.83:1, and the Scorpio diesels and late (97,98) 2.3s had a 0.75:1 5th gear ratio which helps top speed and cruising revs. You'll need to dismantle the box totally, have the original gear taken off and the new one pressed on, then rebuilt. Only give it a go if you have the know-how!
The Youth.
Sep 30, 2015 09:59 PM
dojj
Sep 29, 2015 10:32 PM
DavidK
Sep 27, 2015 02:55 PM
