Alternate Car Brands (Non Ford) For ALL cars that are NOT a Ford
2.0 Zetec into 1.8 ?
Old Apr 5, 2007 | 04:13 PM
escortgti.com's Avatar
escortgti.com
Default 2.0 Zetec into 1.8 ?
Hi there,
I am looking for details on the 2.0 zetec conversion for an Escort GTi.
I have done an engine swap before (albeit a vauxhall) so am quite handy with a spanner or two .
What do I need bar the engine and ecu ?
Can the existing loom be used ?
Fuel lines ?
Starter motor , alternator etc ?
Anything you can tell me would be great , thanks
Gregor
Old Apr 8, 2007 | 08:21 PM
RichieST's Avatar
RichieST
pretty much a straight swap, use your original sump/oil pick up, flywheel. there are a few other bits too, take a look over on escortevolution and there is a full how to on there. you can use your oxisting loom and 1.8 ecu, but if you wish to use 2.0 ecu then you need to change some wiring around where the plug plugs into the ecu, but all the info is over on escortevolution.
rich
Old Apr 15, 2007 | 08:31 AM
djmillsy's Avatar
djmillsy
Fife Radge
rich
you can use the xr3i 130 loom on them
mk3ste
Oct 17, 2021 10:09 AM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
The Enigma
Sep 29, 2015 10:31 AM
mondeomark
Sep 28, 2015 06:28 AM
