Idle
Old Apr 2, 2007 | 04:28 PM
dee00's Avatar
dee00
Default Idle
hi guys, basically i started my car today after about two weeks. After i let it warm up i drove it to my local mechanic and my car was getting a shakey idle after going on boost. Was wondering why this is happening and could it be that i may not have enough oil, as i have a small oil leak.
Old Apr 2, 2007 | 04:40 PM
Moonie's Avatar
Moonie
If your on a standard breather system or an aftermarket breather that is still connected to the metering unit (not vented to atmosphere/catch tank) then an oil leak can also cause an air leak resulting in poor idle.
There are a few other possible causes. Air leak on the intake, faulty HT circuit/plugs, poor setup, sticking metering flap etc...
Old Apr 2, 2007 | 09:54 PM
dee00's Avatar
dee00
whats the best way to find the problem? where do i start?
Old Apr 2, 2007 | 11:11 PM
SafeChav's Avatar
SafeChav
I would strongly recommend anyone that runs an MFI car to disconnect the engines breather system from venting into the airbox, by blocking the pipe on the air box
Currently any air leaks the engine itself develops from things as silly as a leaky sump/rocker gasket will cause running issues
Old Apr 3, 2007 | 12:09 PM
dee00's Avatar
dee00
Bollocks to MFI im going EFI
Old Apr 3, 2007 | 02:07 PM
SafeChav's Avatar
SafeChav
NICE ONE
Old Apr 3, 2007 | 03:05 PM
JamboRS's Avatar
JamboRS
focus rs 1672
done it to mine and im now venting to atmosphere
positives are the car now idles and cruises better,this accompanied by removing dump valve was like driving a completely different car
negatives are the car now smells like exahust fumes with a slight optimax tinge,need to get a catch tank pronto me thinks
Old Apr 3, 2007 | 03:08 PM
SafeChav's Avatar
SafeChav
The fumes are a downfall, you could always run the breather pipe to somewhere at the front of the car
Old Apr 3, 2007 | 04:05 PM
ivorbiggun's Avatar
ivorbiggun
Doesn't everyone have a code 65 BP card for free (company pays for it)
BP102?
Old Apr 3, 2007 | 06:44 PM
JamboRS's Avatar
JamboRS
focus rs 1672
id be too para mate thinking its smoke comin from somewhere,ive currently got it down behind engine pointing towards the ground,ava put a pipe in it to direct as far down as possible and angled under the car so thats part helped,still get the strong smells sittin in traffic though
Old Apr 4, 2007 | 04:24 PM
SafeChav's Avatar
SafeChav
Hmmmmm, duno what to suggest then. The fumes aren't nice or good though?
Old Apr 4, 2007 | 05:32 PM
JamboRS's Avatar
JamboRS
focus rs 1672
ill invest in a oxygen mask for them stuck in traffic times
fordrallycar
Sep 30, 2015 07:57 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
RSmark84
Sep 13, 2015 01:29 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
routemaster
Sep 7, 2015 05:27 PM
