Handbrake light
Old Apr 2, 2007 | 04:01 PM
Mad_Mike's Avatar
Mad_Mike
Default Handbrake light
Ive got 2 lights on my S2 erst that always stay on 1 is the handbrake light the other is ABS.ive got a feeling its to do with the rear disc conversion, but braking is fine. i just want them to go off.
Old Apr 2, 2007 | 05:51 PM
Alvyn's Avatar
Alvyn
have you tried topping the brake reservoir with fluid a little bit over the max mark.
Old Apr 2, 2007 | 09:28 PM
Mad_Mike's Avatar
Mad_Mike
na i havnt tried anything yet but i will do that and see what happens
Old Apr 2, 2007 | 09:56 PM
djmillsy's Avatar
djmillsy
Fife Radge
or taking the bulbs out abs anyway did you remove the rear weight sensors
Old Apr 2, 2007 | 10:47 PM
SafeChav's Avatar
SafeChav
Must be a fault with the brake fluid level sensor, either stuck or the fluid is low.
Steve Escos
Oct 1, 2015 06:57 AM
stevecfrst1
Sep 30, 2015 05:18 AM
deathrider666
Sep 28, 2015 06:12 PM
Sep 28, 2015 10:05 AM
