zvh fuel pump
Old Apr 1, 2007 | 07:47 PM
zvhturbo29rs's Avatar
zvhturbo29rs
Default zvh fuel pump
hi im new to this so please be patient.
ive got a work in progress 300bhp zvh engine in progress and i want to fit it in my xr3i problem is the fuel pump is in the tank not outside like the rs turbo. is there an uprated fuel pump i can put in the tank???any help would be greatfully. many thanks
Old Apr 1, 2007 | 08:30 PM
ZVH,RST's Avatar
ZVH,RST
Default fuel tank
just fit a mfi xr3i,turbo tank, then you can fit a rs turbo/sierra cosworth fuel pump.but you can get a uprated pump for your tank.
Old Apr 1, 2007 | 09:10 PM
zvhturbo29rs
cheers mate
Old Apr 3, 2007 | 01:18 AM
SafeChav's Avatar
SafeChav
Yes you can get uprated in tank senders, a lot easier than pissing about changing your tank and gettting raped buying a new fuel pump bracket!
Old Apr 3, 2007 | 06:09 PM
ChargedT40's Avatar
ChargedT40
Default cossie fuel pump
just fitted a cossie fuel pump into my RS1800 fuel tank it is easy and only £95 from burtons. Some of them have an inspection flap under the back seat but mine didn't so instead of messing around with those corroded bolts and nuts that were snaping as I tried to remove the fuel tank I just used an angle grinder to cut out an inspectionplate under the back seat and then removed the fuel pump from the tank very easy.
Old Apr 4, 2007 | 04:12 PM
SafeChav's Avatar
SafeChav
Default Re: cossie fuel pump
sorry, but
You are an INCREDIBLY brave man blindly using an angle grinder above a petrol tank
Old Apr 4, 2007 | 06:28 PM
jcrsturbo's Avatar
jcrsturbo
just what i was thinking
JK12
33
Apr 26, 2021 12:09 PM
155lee
Oct 27, 2015 04:55 AM
155lee
Oct 24, 2015 11:11 AM
15
Oct 7, 2015 03:43 PM
tib2220
Sep 14, 2015 12:33 PM
