bloody wires
Old Apr 1, 2007 | 06:12 PM
ZOOL's Avatar
ZOOL
Default bloody wires
right got a 1.8 derv fiesta van im having a few problems with. firstly the battery kept dieing on me so did a test alternater not charging. no probs got a new alternater ok for a few days then going to work half five in the morning nothing so moved the cars round jumped it of the astra no probs got to work got home,next day fine day afta starter went. so thought right get new starter new battery fine again for a few days then yes flat, so once again new alternater sort of fine bit slow turning over but goes sometimes. the thing baffeling me is when running fine lights neva dim even with heater and radio on. ive tried all sorts new wires both live an earths added an earth to the shell still the same any help ideas info please im sick of bumping on me own
Old Apr 2, 2007 | 10:09 PM
B19 JUB's Avatar
B19 JUB
sounds to me fella like youve got a severe drain on ya van.best thing to do is use a multimeter on amps and see what drain you have.anything under .5 amp is good but any higher and then your problems could begin as you will need to find out what circuit is draining the battery.easiest way to do this is to have the multimeter on then pull each fuse out 1 at a time,this will give you a clue as to the circuit that is draining then can go from there
Old Apr 3, 2007 | 01:11 AM
SafeChav's Avatar
SafeChav
Does the battery light work?
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
cossie brad
Sep 29, 2015 02:38 PM
IainRS1700T
Sep 25, 2015 06:44 AM
