Multi Plugs on Inlet Manifold
Old Apr 1, 2007 | 01:00 PM
BlueFiesta85's Avatar
BlueFiesta85
Default Multi Plugs on Inlet Manifold
can someone point out where the different coloured multi plugs fit on the inlet manifold just want to make sure ive fitted them correctly, theres a green,black,brown, cream,yellow and blue multi plug, some of the ports have colours on them so ive connected the designated plug to it but there r 3 which im not 100% sure about.
Old Apr 1, 2007 | 02:02 PM
Moonie's Avatar
Moonie
From memory...
Green = Knock sensor
Black = Aux air/warm up valve
Brown = Thermo time switch
Cream = Not sure
Yellow = Temp sensor on bottom of inlet manifold
Blue = Cold start injector
Sure someone will be along to correct me
Old Apr 3, 2007 | 12:27 AM
SafeChav's Avatar
SafeChav
Think you must of imagined the cream one
Old Apr 3, 2007 | 04:05 PM
Moonie's Avatar
Moonie
Yeh got me confused aswell that one
Old Apr 3, 2007 | 04:57 PM
PeteS2RST's Avatar
PeteS2RST
Isnt there a plug that goes on a sensor thats mounted under the Aux air valve ? Is this the elusive cream multiplug???
Old Apr 3, 2007 | 09:29 PM
sheps's Avatar
sheps
Ive got a cream/white one left over after my re-shell.
Hangs around behind the inlet, i was told its a diagnostic port
Old Apr 4, 2007 | 04:59 PM
SafeChav's Avatar
SafeChav
Get a picture up of it. Diagnostics on a RST, if only
Old Apr 4, 2007 | 06:30 PM
sheps's Avatar
sheps
Yep, thats what i thought, i'll get a pic 2moz.
Old Apr 4, 2007 | 08:20 PM
JimmyBoy's Avatar
JimmyBoy
I too have a white one.
Old Apr 5, 2007 | 09:11 AM
sheps's Avatar
sheps
Heres my white plug....who knows what it is then? my car seems to run ok without it??
Old Apr 5, 2007 | 01:38 PM
SafeChav's Avatar
SafeChav
Secondary CTS for the ignition ECU, what year is your car and what code ECU do you have?
Old Apr 5, 2007 | 01:39 PM
SafeChav's Avatar
SafeChav
And unless i am mistaken, that is in fact WHITE. and not CREAM
Old Apr 5, 2007 | 04:43 PM
sheps's Avatar
sheps
I have no idea what year the engines from, its in a cabriolet.
i "think" its a 90spec one,how can i tell?
Ecu code? whats that? you mean the symbols on it?
Old Apr 5, 2007 | 04:46 PM
SafeChav's Avatar
SafeChav
Yea, the coloured squares or if its 90 spec its hearts diamond hash
Old Apr 5, 2007 | 08:25 PM
sheps's Avatar
sheps
Coloured squares, Blue Red and Black.
Whats that plug for then??
Old Apr 5, 2007 | 09:17 PM
Seriesonersturbowady's Avatar
Default Flywheel
sheps
Hi ya m8, can i have a look at the flywheel? bring it with you sunday iff poss, Cheers.
Old Apr 5, 2007 | 10:22 PM
sheps's Avatar
sheps
Yes mate, if i have time to get it off, i'll bring it with me
Old Apr 6, 2007 | 04:05 PM
SafeChav's Avatar
SafeChav
Old Apr 6, 2007 | 06:27 PM
JimmyBoy's Avatar
JimmyBoy
Whats CTS ?
Old Apr 6, 2007 | 08:45 PM
SafeChav's Avatar
SafeChav
Coolant Temperature Sensor
Old Apr 7, 2007 | 12:15 PM
sheps's Avatar
sheps
Originally Posted by JimmyBoy
Whats CTS ?
My thoughts exactly!!
So where does it plug in??
Old Apr 7, 2007 | 05:29 PM
SafeChav's Avatar
SafeChav
There should be a secondary CTS by the auxiliary air device, if you don't have one i have a spare i will sell because i never plan to run MFI ever again even if someone paid me to
Old Apr 11, 2007 | 07:29 PM
JimmyBoy's Avatar
JimmyBoy
I have this one not connected as well, just remembered! lol, im not sure where the auxillary air device is to locate the CTS.
Old Apr 11, 2007 | 10:22 PM
SafeChav's Avatar
SafeChav
Follow the hard plastic pipe connected to the throttle body and you will find it
tankybaby66
Feb 6, 2016 02:24 PM
A.t.p
Oct 23, 2015 07:54 PM
Fudgey
21
Sep 30, 2015 06:19 PM
Johnny Knoxville
Sep 30, 2015 07:21 AM
caprixpack
Sep 25, 2015 07:53 PM
