identifieng ofac map sensor
Mar 31, 2007 | 04:37 PM
i ahve a funny feeling that someone on ebay has sold me the wrong map sensor,mine is square whereas all the pics i look at have a triannge shape?
Apr 3, 2007 | 12:06 AM
It looks identical to a 3i map sensor, except one of the corners is at a funny angle if that makes sense?
Get a picture up i can soon I.D it for you
Apr 3, 2007 | 08:50 AM
should look like this
Apr 3, 2007 | 09:14 AM
the corner on mine is not angled like the pic,mine is like a square shape without the slanted corner,do i have the wrong one?
Apr 3, 2007 | 09:28 AM
this is the one i bought
Apr 3, 2007 | 03:04 PM
Bad luck
ian r i wouldn't says yours is a OFAC item either, they are different to that!
Apr 3, 2007 | 03:06 PM
Apr 3, 2007 | 03:08 PM
shit,thanks mate at least i know what im looking for now cant belive i fell for that.
would it effect how it runs with the wrong map sensor,could i have dmaged anything by starting it the other day?
Apr 3, 2007 | 03:11 PM
Yea it would affect it, although i doubt you've caused damage, just dont get boosting it until you have a proper one!
The OFAC ones are always that obscure shape, and usually have a metal tag on the front with the part number.
might be worth getting an OFAB ECU and using a marelli map?
Apr 3, 2007 | 03:33 PM
wish i had now,but already have bought the ofac ecu,if i see an ofab 1 cheap enough i will snap it up though
Apr 3, 2007 | 03:34 PM
Gives you a little more room for tuning aswell with OFAB because you can go up to a 3 bar one
Apr 3, 2007 | 03:46 PM
just getting it running right andd an mot would be a bonous after 3 years of being garaged
Apr 3, 2007 | 03:54 PM
Mine had a years MOT on it and its probably done 5 miles since, and its run out again now
You still got that EFI orion there?
Apr 3, 2007 | 04:15 PM
Apr 3, 2007 | 04:16 PM
cool.
PM sent
Apr 3, 2007 | 07:31 PM
not being funny but are u sure its just that 1 had different part numbers to the 3i one i got with the loom???
might explain y my car over fuels when it boosts
Apr 4, 2007 | 07:57 AM
better pic looks like ive been stitched up aswell
Apr 4, 2007 | 08:20 AM
Quote:
that map sensor is the same as what ive got and i got mine off sum1 that was stripping a fiesta rst so unless hes messed me about aswell,seems a bit strange that theres 2 so far that cud b wrong and b totally different from an xr3i map sensor
Apr 4, 2007 | 08:39 AM
mine is correct just taken it off the car those first pics i done dident show the angled bit
part number on it is v90fb-9f479-aa
Apr 4, 2007 | 05:03 PM
That picture is a much better one, and i can confirm that is an OFAC MAP sensor
Apr 5, 2007 | 08:27 AM
Quote:
thats a relief then ive got the correct 1 aswell
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
timsrs
Nov 13, 2018 11:48 AM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
jay030787
Sep 25, 2015 01:38 AM
