s2 gearlinkage adjustment
Old Mar 31, 2007 | 03:38 PM
escort1.616v's Avatar
escort1.616v
Default s2 gearlinkage adjustment
please could some one tell me the correct way to adjust my gearlinkage i have just fitted a clutch and i dont no the set up procedure,
thank you
Old Mar 31, 2007 | 05:55 PM
escrst's Avatar
escrst
i may be corected but thinking select reverse on gear box by pulling pin to neutral twisting all the way to drivers side then push it in towards gear box. then get a mate to hold gear nob in reverse location while you do up the clamp. let me know if that makes sense
Old Apr 1, 2007 | 09:39 AM
escort1.616v
i have just set it up your way mate it clears all gears while the engine aint running so hopefully should be ok gonna try and change the clutch ratchet now
Old Apr 3, 2007 | 12:11 AM
SafeChav's Avatar
SafeChav
Replied to your PM
yatta
May 21, 2016 10:31 PM
mk1turboestate
Dec 2, 2015 08:31 PM
Fezman1
Oct 2, 2015 01:22 PM
IainRS1700T
Sep 25, 2015 06:44 AM
coscor86
Sep 20, 2015 01:21 PM
