saph cos leather into s2?
Old Mar 31, 2007 | 08:55 AM
COSSIE CAL's Avatar
COSSIE CAL
Default saph cos leather into s2?
how do i do this?seen an s2 with it done and was just asking how its done please,cheeRS
Old Mar 31, 2007 | 10:02 AM
antony215's Avatar
antony215
Escort Rs Turbo
If you do it you do know the back seats dont fit properly
Old Mar 31, 2007 | 11:06 AM
COSSIE CAL's Avatar
COSSIE CAL
thats what im asking,how do i modify them to fit?
Old Mar 31, 2007 | 11:07 AM
KSA-Cossie's Avatar
KSA-Cossie
Aren't the saph recaros wider then the rst ones.
Old Mar 31, 2007 | 11:21 AM
COSSIE CAL's Avatar
COSSIE CAL
think so,feel like it,but i need to know how to mod the rears
Old Mar 31, 2007 | 11:25 AM
KSA-Cossie's Avatar
KSA-Cossie
I remember a feature car in fast ford years back with saph recaros in the front and he had to retrim the back seats
Old Mar 31, 2007 | 11:29 AM
COSSIE CAL's Avatar
COSSIE CAL
i think thats what ill have to do.but i want to retrim the whole interior in yellow cloth,or red
Old Mar 31, 2007 | 11:34 AM
KSA-Cossie's Avatar
KSA-Cossie
hell nnnoooooooooooooo
Old Mar 31, 2007 | 11:47 AM
antony215's Avatar
antony215
Escort Rs Turbo
See if you can swop the runners from you escort seats to the cossie ones if not have them welded on to the cossie seats. The back ones are completly different so you need to get them retrimed i think i was told the the above car just took the leather off the cossie seats and put it on the escort seats but if you look close that has big gaps on each side at the back If i was you mate i would get you escort seats retrimed because the cossie ones dont tilt forward either
Old Mar 31, 2007 | 09:08 PM
Moose's Avatar
Moose
saff front ones are wider and dont lean forward unless you turn the adjuster thing like mad lol, you could try fitting escort runners but i imagine you will have to weld in a plate to make them fit. The rear ones that are in the photo are are saff rears, you would have to cut the 3 inch raised bit off the back of the bench and some how bolt the backs to a frame, as saffs latch bit is int the middle off the two not at the side, i think the guy has used them tho as they dont go to the edge as he has a roll cage bolted to the inner wheel arches so a retrim would be needed unless your goin for a cage and not usin the rear seats.
rich
Old Mar 31, 2007 | 11:06 PM
fatboy billy's Avatar
fatboy billy
the front seast fit with the runners swapped dont know if they will go straight on tho as for the rear seat the bottom half that you sit on strip the cloth of the escort seat and the leather of the sierra seat and swap them over then with the back rest part of the seat you make them so they are as 1 strips of metal across the back holding them together as they are a 60/40 split they will fit like this but they are a bit narrow and the bits that would go down the side in the sierra are too big so you would need to mak something of your own hope that helped
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
stevecfrst1
Sep 30, 2015 05:18 AM
