Is my fuel preasure regulator fuked?
Mar 29, 2007 | 07:48 PM
right every time i shut my car off leaving it for about 5 mins or so it wont start due to fuel flooding into the air box and wen it dose start its horriblley missing til all the flooded fuel is burnt, i am just wondering if my fuel preasure regulator is not allowing fuel to go back to the tank can that be building the preasure up and forceing the fuel to leak out the float pin?
Mar 30, 2007 | 12:34 PM
how many times do i have to tell you
YOUR METERING HEAD IS FUCKED
Mar 30, 2007 | 01:46 PM
He's right you know
Mar 30, 2007 | 08:30 PM
ive sorted it you haynes manual
the seals inside were nackerd along with the float pin i replaced the lot with new ones
wont ask this again
Mar 30, 2007 | 08:35 PM
Mar 30, 2007 | 08:36 PM
looool pm me the price even thow myns perfect and like new now
Mar 30, 2007 | 09:49 PM
How else does fuel enter the airbox then
the regulator is outside the air box?!!!!!!!!!!
Mar 30, 2007 | 10:05 PM
noo theres a small seal were the float pin is i figure that fuel wasnt returning to the tank and building upinside the unit and forceing its way out the float pin area my regulator was fuked aswel as my seals on the metering unit i changed the lot with new ones nows its all gud lol
Mar 30, 2007 | 10:15 PM
So why are you asking if you regulators fucked
Mar 30, 2007 | 10:16 PM
cos i had the problem then now i sorted it
Mar 30, 2007 | 10:22 PM
Im lost you only posted up yesterday
Mar 30, 2007 | 10:23 PM
i know i figured it all out and got the bits
Mar 30, 2007 | 10:25 PM
Ah
So did you say you got seals for inside the metering head?
If so where did you get them just for reference
Mar 30, 2007 | 10:27 PM
yup if you check the last page on my thread u will see few pics i got them of ebay for a 5ver
Mar 30, 2007 | 10:33 PM
That was a lucky find
Didn't have to dismantle the metering head then to fit them?
Mar 30, 2007 | 10:35 PM
nope just open the 3 screws on the top unit with the pipes and a 19mm spanner to open the bolt below ones thats off its straight forward
Mar 30, 2007 | 10:39 PM
Mar 30, 2007 | 10:42 PM
Mar 30, 2007 | 10:44 PM
Mar 30, 2007 | 10:45 PM
Mar 30, 2007 | 10:46 PM
Mar 30, 2007 | 10:50 PM
Mar 30, 2007 | 10:51 PM
Mar 30, 2007 | 10:53 PM
Mar 30, 2007 | 10:54 PM
Mar 30, 2007 | 10:55 PM
Mar 30, 2007 | 10:56 PM
Mar 30, 2007 | 11:07 PM
Mar 30, 2007 | 11:18 PM
Mar 30, 2007 | 11:22 PM
mohamid safe chav ali
Mar 30, 2007 | 11:25 PM
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
20/20 vision
Sep 29, 2015 11:27 AM
