Problems with a S2 stalling
Old Mar 28, 2007 | 08:24 PM
MJC's Avatar
MJC
Default Problems with a S2 stalling
Just had a call from a mate. He's having trouble with his S2 stalling. It will only do it when its idleing!" The engine will be running fine and then it will just die like someone has turned the key does anyone have any ideas....? If you try startin the engine again, it will fire up fine. I am completely stupped
Old Mar 28, 2007 | 09:25 PM
JamboRS's Avatar
JamboRS
focus rs 1672
air leak
Old Mar 29, 2007 | 08:54 AM
MJC's Avatar
MJC
Wouldn't an air leak be a constant problem....? the engine runs fine and then randomly just stalls
Old Mar 29, 2007 | 10:45 AM
JamboRS's Avatar
JamboRS
focus rs 1672
an air leak can show no symptoms when driving,it just wont idle with an air leak
check all boost/vacuum hoses also check the brake vac hose,there renowned for cracking splitting and leaking air
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
