Modd grey injectors??
Old Mar 28, 2007 | 11:56 AM
JanDK's Avatar
JanDK
Default Modd grey injectors??
I have heard that it is a good idea to either remove the yellow injectorcap or modd it to give it better spray
Anyone??
Old Mar 28, 2007 | 12:39 PM
jon@work's Avatar
jon@work
yes - either
Old Mar 28, 2007 | 04:22 PM
WHY ?
Old Mar 28, 2007 | 05:04 PM
Alvyn's Avatar
Alvyn
Originally Posted by tabetha
WHY ?
without doing either to it the spray pattern as standard of a grey 403's or light blue 400's injectors ISN'T good for a yb engine and could result in having a melted engine!
Old Mar 31, 2007 | 08:08 AM
JanDK's Avatar
JanDK
But what modification are we talking about... is it removing the cap or drill a bigger hole in it???
Old Mar 31, 2007 | 11:31 AM
Alvyn's Avatar
Alvyn
you CAN do it either way as stated above by Jon@work!
I have the caps removed on my own if that helps!
Old Mar 31, 2007 | 01:46 PM
JanDK's Avatar
JanDK
Ok.. was not sure that that it actualy was ok to remove the cap, but that all of you! I will do that
mk3ste
Oct 17, 2021 10:09 AM
Mark_
14
Jan 16, 2016 05:27 PM
Nov 1, 2015 06:53 PM
Fil
Sep 30, 2015 12:08 PM
