focus 1.6 zetec 2001. - engine light on
Old Mar 27, 2007 | 11:08 AM
paceo's Avatar
paceo
Default focus 1.6 zetec 2001. - engine light on
just popped this post up for a friend at my work.
what are the most common things to look for when the engine light comes on? the car still drives fine. its a 2001 ford focus black 1.6
only thing is though the front brakes need changing and thats it.
Old Mar 27, 2007 | 05:02 PM
cpaul4's Avatar
cpaul4
The sensors by the exhaust cat there is two, one of mine came loose and that brought up my light.
Old Apr 18, 2007 | 08:58 PM
atticus1985's Avatar
atticus1985
the engin light on my 1.6 focus came on for no reason i could see but then i couldn't get the power down on the road, turns out the the ignition coil needed changing not too expensive but the bloody thing is back on again now so looks like is gonna be more ŁŁŁ's
Old Apr 21, 2007 | 12:27 AM
leeboy's Avatar
leeboy
Default problems
theres a number of things that can cause the light to come on sometimes the the ecu may have picked up a wrong signal which would also bring the light on if thats the case then the dtc would need to be cleared but common problems are coil pack o2 sensors air mass more so if induction fitted
Old Jun 28, 2007 | 10:26 PM
madchris's Avatar
madchris
MY ENGINE LIGHT CAME ON BUT HAD NEW CLUTCH PUT IN AND IT WENT OFF
Old Jun 29, 2007 | 10:33 AM
watson's Avatar
watson
Disconect the battary for 10 mins it will reset the ecu see if it comes back on, if it does then its worth getting it checked if not then its just had a bad signal.
But i thought the new focus's had sensors on there breaks like you said so you know when there low.
Old Jul 3, 2007 | 01:10 PM
rafblackfoci's Avatar
rafblackfoci
you will need to leave it for 30 - 45 mins to reset the ecu, 10mins wont do it, plus make sure you have the radio code before you do it
David
JoeyBoyden
Jan 4, 2024 02:36 PM
taylora1409
Aug 12, 2015 12:06 PM
