Dry CVH
Old Mar 26, 2007 | 07:21 PM
mattxr3i's Avatar
mattxr3i
Default Dry CVH
My xr3i sounds fine when cold but as soon as it gets warm, when reving it hard it sounds rough, really dry. Above 3k you can hear the tappets! I am using magnatec 10W40 semi synthetic oil, i am thinking thicker oil may help it! THe cam and tapppets are relatively new, 4k and it was run in properly. Sounds to me that the oil is getting too thin! What do you lot think
I have done an oil pressure check a little while ago and it was a fraction above what the Haynes manual says so @ 2k around 40psi
Old Mar 26, 2007 | 07:25 PM
SafeChav's Avatar
SafeChav
Either your oil pumps knackered or (dare i say) your new cam and lifters is
mk3ste
Oct 17, 2021 10:09 AM
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
sridgett
13
Sep 27, 2015 06:03 PM
Russp
Escort Range
Sep 18, 2015 07:39 PM
