series two clutch adjustment
Old Mar 26, 2007 | 04:21 PM
PeteS2RST's Avatar
PeteS2RST
Default series two clutch adjustment
After refitting my engine the clutch arm is right against the gearbox housing and i cannot press the pedal down.
how do i adjust it do i need to take the arm off the release lever or can i remove and refit the cable at the pedal and let the quadrant adjust itself?
Any help appreciated
Old Mar 26, 2007 | 04:26 PM
Obviously you let the pedal tqake up the slack when you disconnected the cable at gearbox ? before the pedal.
Just shove a thin flat screwdriver between the quadrant and ratchet adjuster teeth and it will go ping and unadjust then a few pumps to self adjust on the pedal and all is well again.
Old Mar 26, 2007 | 04:29 PM
PeteS2RST's Avatar
PeteS2RST
Tabetha thanks for a speedy reply.
Removed ABS whilst engine was out and i think my assistant may have stepped on the clutch instead of the brake when we were bleeding them
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
AJC
Oct 8, 2015 11:09 AM
Fezman1
Oct 2, 2015 01:22 PM
Kiran1600E
11
Oct 2, 2015 11:35 AM
