glowing red turbo
Old Mar 26, 2007 | 12:13 AM
ZVH,RST's Avatar
ZVH,RST
Default glowing red turbo
when i am giving it death my turbo glows red, only the manifold to turbo area, ie near the 4 bolts that hold the turbo to manifold. is this normal the car runs and boosts mint,
Old Mar 26, 2007 | 05:27 AM
T28 RST's Avatar
T28 RST
Ok then
Normal
Old Mar 26, 2007 | 07:15 PM
akito-man's Avatar
akito-man
From: fee,fife,foe,fumb,i smell the blood of an englishman ,in scotland!
mine too,bright red ,glowing in the bonnet space,who needs bonnet neons
just dont touch it to check
Old Mar 26, 2007 | 08:06 PM
Mixja's Avatar
Mixja
420
usually means your timing is slightly off, exhaust valves opening too early....
Old Mar 26, 2007 | 08:14 PM
akito-man's Avatar
akito-man
nah,just been kikin de arse oot of it ,its ok after a normal run,but i
ll be gettin a set up soon enough tho
Old Mar 26, 2007 | 11:33 PM
ZVH,RST's Avatar
ZVH,RST
ok cheers so i need to move my cam timin back a little on my vernier pulley. but am sure my top timin mark is dead on 12 o clock.
Old Mar 27, 2007 | 05:00 AM
JesseT's Avatar
JesseT
Could be lean on fuel, too little ignition timing or too much cam advance. Can't really say it's normal, though it might be a "feature".
Old Mar 27, 2007 | 09:20 AM
Davie's Avatar
Davie
every turbo car i've seen thats been given a bit of death has had the turbo glowing.
Don't touch it, or you will vapourise your hand.
Old Mar 27, 2007 | 12:27 PM
Mixja's Avatar
Mixja
420
yeah, but get it set up properly on the rollers...
Old Mar 27, 2007 | 08:47 PM
PeterD's Avatar
PeterD
sounds normal to me, dont worry about it as prolonged high revs like say 4-5k motorway miles or something like will make you glow.
However as alwys get your RS set up at a tuner, do this when you buy one
you never know.......
Old Mar 27, 2007 | 09:13 PM
rapidcossie's Avatar
rapidcossie
As Lucid says, normal motorway driving is enough to get your turbo glowing.
Old Mar 27, 2007 | 09:41 PM
ZVH,RST's Avatar
ZVH,RST
ok cheers
Matt Baxter
Sep 16, 2015 08:30 PM
Bailes1992
Sep 3, 2015 02:17 PM
mrknifey
Aug 30, 2015 11:48 AM
Bailes1992
Aug 16, 2015 07:14 PM
muz
Aug 16, 2015 12:57 PM
