fuze box, how to remove?
Old Mar 24, 2007 | 11:05 AM
miched's Avatar
miched
Default fuze box, how to remove?
hello peeps
im trying to take the fuse box out of my s2, i can see the screwa under the dash but as far as i can tell they need to be unscrewed from the engine bay?
can anyone give me a guide?
cheers
Old Mar 24, 2007 | 11:27 AM
Micky's Avatar
Micky
Yes mate,from inside the engine bay look at the fuse box.The sides of the fuse box need to be pulled apart slightly so that the part all the fuses are pushed into can be lifted up and out of the fuse box.With this out of the way you will then be able to look into the fuse box and see 3 screws.These have rubber washers between the base of the box and the cars metalwork to stop water getting into the car around the screws,dont lose them if you can held it!!Regards,Micky
Old Mar 24, 2007 | 11:52 AM
miched's Avatar
miched
We will try that now! Thanks for your help!
Old Mar 24, 2007 | 03:55 PM
SafeChav's Avatar
SafeChav
The fuse box can only be removed with the entire loom though, just incase you didn't know.......
Old Mar 24, 2007 | 05:11 PM
miched's Avatar
miched
just figured that out, only needs the surface rust grinding and a lick of paint....
now i really cant be bothered, seems like far too much hassle
Old Mar 24, 2007 | 05:21 PM
SafeChav's Avatar
SafeChav
It is a pain in the ass
Old Mar 24, 2007 | 06:11 PM
miched's Avatar
miched
do you fancy giving me a hand
i wouldnt know where to start
Old Mar 24, 2007 | 06:12 PM
SafeChav's Avatar
SafeChav
What ripping a loom out?
Old Mar 24, 2007 | 08:14 PM
miched's Avatar
miched
i think im going to have to rip th loom out to do the welding, unless there is another way....its only surface rust
Old Mar 24, 2007 | 11:25 PM
SafeChav's Avatar
SafeChav
If you need to weld its obviously more than surface rust
Old Mar 25, 2007 | 08:18 AM
miched's Avatar
miched
seen
it only looks like surface rust and im being very hopefull, but im expecting the worst
Old Mar 25, 2007 | 08:28 PM
SafeChav's Avatar
SafeChav
Old Mar 26, 2007 | 12:12 AM
Diamonds.'s Avatar
Diamonds.
glad someone posted about this before i took mine out now i will know what im doing before i end up screaming SHIT so loud they hear it in Australia
Old Mar 26, 2007 | 01:22 PM
SafeChav's Avatar
SafeChav
Not the most fun job in the world, but id rather remove a loom than say change a clutch pedal quadrant
Dr. Ickxs
Sep 15, 2015 10:15 PM
grishenko45
Sep 9, 2015 12:58 PM
andrewmctiernan
Sep 8, 2015 03:05 PM
Rizlablue
Sep 6, 2015 09:58 AM
hopper350
Sep 4, 2015 12:53 AM
