flamer kit
Old Mar 23, 2007 | 05:18 PM
sy.rst's Avatar
sy.rst
Default flamer kit
iv fitted a flamer kit 2 my s2 but im finding it realy hard 2 get flames.i was thinking bout wireing up a the cold start injector 2 a switch on the dash so i can flick it on to richen up the fuel and produce more flames.any one know if this would work or is it dangerous.
Old Mar 23, 2007 | 05:59 PM
SafeChav's Avatar
SafeChav
Compromising your engines performance and reliability for some flames
Not worth it IMO
Old Mar 23, 2007 | 06:04 PM
KSA-Cossie's Avatar
KSA-Cossie
I had one on my old s2,best to boot it then when on the over run give it a tiny bit throttle and you'll soon get flames
Old Mar 23, 2007 | 06:20 PM
sy.rst's Avatar
sy.rst
how will it affect the performance or reliability?
Old Mar 23, 2007 | 06:23 PM
KSA-Cossie's Avatar
KSA-Cossie
Also whats your co set at m8 ?
Old Mar 23, 2007 | 06:25 PM
SafeChav's Avatar
SafeChav
If your using the cold start injector to bung fuel through the cylinders then its guna be running rich as fuck!
Not adviseable
Old Mar 23, 2007 | 06:54 PM
*Bri.4.b.Cos*'s Avatar
*Bri.4.b.Cos*
Exactly what i used to do, works every time, especially when exhaust is HOT
Bri.
Old Mar 23, 2007 | 08:10 PM
sy.rst's Avatar
sy.rst
duno what the co is set at have not had it set up yet.
Old Mar 23, 2007 | 10:57 PM
oadamo's Avatar
oadamo
couldnt you wire your car up so that you have a coil in the boot with a plug in the exhaust. but will cut the front coil and switch to the back coil. so that when you rev it hard and press the switch all the fuel will pass throw the engine???
adam
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
