zvh exhaust
Old Mar 23, 2007 | 11:21 AM
meacher's Avatar
meacher
Default zvh exhaust
hi people just got myself a wild zvh frst im thinking of changing the exhaust as the 1 thats on is knocking like fxxk when in idle and on the move it is 4inch from turbo to the end it has stage 3 turbo,,will a normal frst exhaust fit right on and a quick 1 it has 4 pot calipars on i want to change the pads what type will i go for...
cheers guys
Old Mar 25, 2007 | 08:44 AM
RS 5tu's Avatar
RS 5tu
I think i may have the answer when i built my zvh had the same problem look at the exhaust is it clearing the sump? mine was hitting the sump giving me the same rattle if it is your sump you could change it for other zetec sump or get the corner cut off and tig weld it back up
tankybaby66
Feb 6, 2016 02:24 PM
Cosnada
Jan 7, 2016 05:30 PM
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
