efi rev counter
Old Mar 22, 2007 | 04:17 PM
RST Ski's Avatar
RST Ski
Default efi rev counter
ive wired mine up to the edis module using my original mfi loom to the speedo from the original coil, think its still reading wrong, do i need to wired up both green wires from the original coil??
Old Mar 22, 2007 | 05:27 PM
Moonie's Avatar
Moonie
If your tachometer was previously driven by a single coil, your tachometer will need input from two coils to indicate properly. Below is a simple circuit showing how to interface the EDIS system with your tach:
Go to Maplins for the bits.
Old Mar 22, 2007 | 06:42 PM
RST Ski's Avatar
RST Ski
wont the fezzy coil pack be the equivalent to 2 mfi coil packs then?
sorry to seem stupid but whats the d1 d2 bits ect?
Old Mar 22, 2007 | 06:48 PM
tim10_10's Avatar
tim10_10
Sorry to hi jack the post but got similar problem with my car got coil packs using a p8. In the diagram are the traingle bits diodes? If so where do you get them from?
Old Mar 22, 2007 | 07:01 PM
Micky's Avatar
Micky
Get the stuff from Maplins,as wrote above already!!!Regards,Micky
Old Mar 22, 2007 | 07:06 PM
tim10_10's Avatar
tim10_10
didnt see that!
Old Mar 22, 2007 | 07:07 PM
Moonie's Avatar
Moonie
Yup, three diodes (D1,D2 & D3), D3 is a zener diode.
So you want 2X 1N4004 and 1X 1N4746 (should set you back about 50p )
Best thing to do is print off that diagram and take it to Maplins
Old Mar 23, 2007 | 01:40 PM
1.9s1's Avatar
1.9s1
If you connect the original green tacho wire to edis pin 11 then it will read fine. you will need to put an extra pin in the edis plug though as it doesn't have one for pin 11.
Old Mar 23, 2007 | 02:30 PM
y4n's Avatar
y4n
1.9s1 is this method using the MFI clocks or did you have to change them to get the revs to work at pin 11?
Old Mar 23, 2007 | 03:15 PM
RST Ski's Avatar
RST Ski
rrr yes just checked mine, where can i get the bits to put another pin in? need a kit of some kind
if the rev counter isnt wired up properly as mine is now, would this cause proplems for the idle and the set up of the idle ?
heres my problem
https://passionford.com/forum/viewtopic.php?t=258766
Old Mar 23, 2007 | 03:35 PM
SafeChav's Avatar
SafeChav
Pin 11 of the EDIS should be the easiest solution.
Old Mar 27, 2007 | 08:01 PM
RST Ski's Avatar
RST Ski
anyone done this method? added a extra pin?
Old Mar 28, 2007 | 01:09 AM
SafeChav's Avatar
SafeChav
what you havin trouble with mate?
Old Mar 28, 2007 | 01:37 PM
y4n's Avatar
y4n
Probably same problem i have, he must of added another pin and it still dont work.
Old Mar 28, 2007 | 01:47 PM
SafeChav's Avatar
SafeChav
Doesn't work in what way?
Old Mar 28, 2007 | 02:51 PM
y4n's Avatar
y4n
rev counter doesnt read at all.
Old Mar 28, 2007 | 02:58 PM
RST Ski's Avatar
RST Ski
duno how to go bout adding a extra pin in the edis block connecter so that pin 11 is added
Old Mar 28, 2007 | 03:46 PM
SafeChav's Avatar
SafeChav
I think you just drill a small hole as the back piece of plastic is blonked over, and then you can insert a pin. You'd need to go down the scrappy and get a pin out of another EDIS plug though
Old Mar 28, 2007 | 05:27 PM
RST Ski's Avatar
RST Ski
rrr i see
Old Mar 28, 2007 | 05:29 PM
SafeChav's Avatar
SafeChav
Old Apr 4, 2007 | 06:34 PM
RST Ski's Avatar
RST Ski
just thought, where does a fezzy turbo get its rpm signal from then if theres no pin in number 11
Old Apr 4, 2007 | 06:50 PM
SafeChav's Avatar
SafeChav
The rev counter is calibrated to accept the signal from one of the DIS coils.
Old Apr 4, 2007 | 06:56 PM
RST Ski's Avatar
RST Ski
if the rpm isnt wired up would this afect the idle behavier?
Old Apr 4, 2007 | 06:59 PM
SafeChav's Avatar
SafeChav
nope
Old Apr 4, 2007 | 07:01 PM
RST Ski's Avatar
RST Ski
r ok, cos i know when you set the idle you have to hold it a certain revs, with the idle valce disconnected, but wonderd if it read that through the ecu or the speedo
Old Apr 4, 2007 | 07:07 PM
SafeChav's Avatar
SafeChav
Nah it only measures the low tension signals
Old Feb 4, 2009 | 08:54 PM
16vzetec's Avatar
16vzetec
http://www.feoc-uk.com/forums/index.php?showtopic=60953
Old Jun 15, 2013 | 08:07 AM
Cameron's Avatar
Cameron
Do the negative side of coil 1 and 2 mean the original green wires going to the ignition coil on the s2?
Old Dec 24, 2014 | 11:47 AM
Red_bull's Avatar
Red_bull
I have set this up, however my needle is sometimes accurate and sometimes just lays in the corner. Is my revcounter broke? Signal looked good on scope!
Old Dec 24, 2014 | 10:36 PM
mentalasanything's Avatar
mentalasanything
Swap the 1n4746 for a 1n4744, it has a slightly lower voltage rating. I don't seem to have any issues with mine.
Lee
mk1turboestate
Dec 2, 2015 08:31 PM
liamT74
Sep 23, 2015 10:24 PM
davidfordrs
Sep 21, 2015 04:23 AM
RSmark84
Sep 13, 2015 01:29 PM
dms04
Sep 11, 2015 01:57 PM
