Electrical problem
Old Mar 22, 2007 | 03:29 PM
sheps's Avatar
sheps
Default Electrical problem
Just completed a re-shell, and think i may have gone wrong somewhere??
I can start the car fine, with no problem most of the time.
But then sometimes, it wont start, just like there is no starter motor connected??
And if it does start, when i come to turn it off, 75% of the time, the starter motor stays spinning??
What have i connected up wrong
Old Mar 22, 2007 | 05:15 PM
antony215's Avatar
antony215
Escort Rs Turbo
Sounds like your stater is fucked to me mate it sounds like its just not releasing after it's started the car.
Old Mar 22, 2007 | 05:31 PM
Moonie's Avatar
Moonie
As Anthony says its proably a sticking solenoid in the starter.
Check you only have +12v down the trigger wire to the starter with the key in position 3/crank position. If thats switching ok then i would say ther starter is faulty.
Old Mar 22, 2007 | 08:40 PM
sheps's Avatar
sheps
Hmmm it might be, didnt think of that, it was a second hand one, i melted the last one on the motorway.
I'll get another and see what happens
Old Mar 22, 2007 | 09:07 PM
B16 WLD's Avatar
B16 WLD
check your ignition switch too.
if this is the second one, maybe it is sticking on
Old Mar 22, 2007 | 09:33 PM
SafeChav's Avatar
SafeChav
Ignition swtich would be my bet.
If the starter solenoid was staying engaged it would be making a right fucking racket
Old Mar 22, 2007 | 09:55 PM
Diamonds.'s Avatar
Diamonds.
yeh and dont hold the key on like i did melted my battery and loom
Old Mar 22, 2007 | 10:06 PM
SafeChav's Avatar
SafeChav
HOW??????!!!!!!!!!!!!!
Old Mar 22, 2007 | 10:09 PM
sheps's Avatar
sheps
Yep,its not quiet, sounds like an aeroplane taking off
Old Mar 22, 2007 | 10:11 PM
sheps's Avatar
sheps
The only way i could get it to stop spinning was either dis-connect the battery, or give the motor a small tap with a jack handle
Old Mar 22, 2007 | 10:12 PM
SafeChav's Avatar
SafeChav
Starter then
2 options really, trying smashing the largest object into the starter that u can find, it may come unstuck, or remove the starter and disconnect the main positive starter cable from the battery and bump the car.
You dont waste any cash that way, and should be able to prove the fault
Old Mar 22, 2007 | 10:16 PM
sheps's Avatar
sheps
Defo the starter then mate?
I dont think i'll try smashing it, i did that with last one, managed to put a hole the size of a golf ball in it
Old Mar 22, 2007 | 10:21 PM
SafeChav's Avatar
SafeChav
If you say tapping it solves your problem it must be the starter
Probably repairable aswell if your wallet has seen better days
Old Mar 22, 2007 | 10:23 PM
sheps's Avatar
sheps
Ah marvelous, cheers very much
I think ive got a spare hanging around somewhere, i'll try that before i go about repairing it.
Old Mar 22, 2007 | 10:24 PM
antony215's Avatar
antony215
Escort Rs Turbo
Remind me never to get any betting tips from you
Old Mar 22, 2007 | 11:49 PM
SafeChav's Avatar
SafeChav
Well had the Author of mentioned the ever so slightly significant "it sounds like an airplane" i wouldnt of bet that
ALRIGHT
Old Mar 23, 2007 | 01:39 PM
sheps's Avatar
sheps
Slipped my mind
Old Mar 23, 2007 | 01:44 PM
antony215's Avatar
antony215
Escort Rs Turbo
Have you sorted it now then
Old Mar 23, 2007 | 02:03 PM
sheps's Avatar
sheps
No, i wont get the chance until saturday, the cars having some work done for the mot
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Kam B
Sep 24, 2015 10:40 AM
focus2351
Sep 9, 2015 09:33 PM
