gear linkage
Old Mar 21, 2007 | 02:38 PM
lewis_lisa's Avatar
lewis_lisa
Default gear linkage
how hard is it to change the linkage and what does it cost for a new 1 as im still having prob getting car into gear sometimes esp reverse
Old Mar 21, 2007 | 02:45 PM
antony215's Avatar
antony215
Escort Rs Turbo
Linkage might just need adjusting up properly. But it aint a hard job to change it's 4 10mm bolts inside the car and to bolts under the car (that connect to the box) a 13MM and a 19mm (i think) should take you no longer than an hour
Old Mar 21, 2007 | 04:23 PM
Gav Diamond's Avatar
Gav Diamond
I am trying to find a new one for my car aswell as mine is worn.
I have been told this is still availiable from Ford but my local one will not look to see if any branches have any in.
Gav
Old Mar 21, 2007 | 04:55 PM
jimmylaud's Avatar
jimmylaud
i just got a new one from ford got the whole rod with the u/j joint on the end just ready to fit its was only £23 that was kirkcaldy ford garage hope this helps
Old Mar 21, 2007 | 05:21 PM
Gav Diamond
Can you give me the finis code please?
Old Mar 22, 2007 | 02:25 PM
jimmylaud's Avatar
jimmylaud
yes no probs mate its at my pals house hes the one that sorts the car should be up there on saturday once i get it ill let u know
Old Mar 23, 2007 | 07:03 PM
Gav Diamond
Thanks that will be great
Old Mar 23, 2007 | 07:53 PM
ivorbiggun's Avatar
ivorbiggun
Do yourself a favour get a BM quick shift
Old Mar 24, 2007 | 12:01 AM
SafeChav's Avatar
SafeChav
Clutch might not be disengaging if gears are hard to select?
Is 1st hardest to select? And does reverse crunch like a mother fucker
tankybaby66
Feb 6, 2016 02:24 PM
The Youth.
Sep 30, 2015 09:59 PM
dojj
Sep 29, 2015 10:32 PM
cameron2
Sep 23, 2015 06:31 PM
