offset of 55 on 8jx17 ok for saff 4x4?
Old Mar 21, 2007 | 10:19 AM
Cawood's Avatar
Cawood
Default offset of 55 on 8jx17 ok for saff 4x4?
Quick question
is an offset of 55 on 8jx17 ok for a saff 4x4?
need to get some new alloys fast n i have found some on ebay for sale
these are meant to be ford fitment he has put on the auction
these are the details copied off the auction
Aspect Ratio: 40
Offset: 55
Load Index: 91
will they be ok? is one of those the PCD?
Old Mar 21, 2007 | 10:23 AM
RichardPON's Avatar
RichardPON
Completely wrong. Sure that's not a Ford fitment on a later car with 5 stud or something?
Old Mar 21, 2007 | 10:30 AM
Cawood's Avatar
Cawood
is it? bugger
scrap that idea then?
there a 4 stud
is one of the details the PCD?
cheer rich, thought i'd found myself a cheap set of mo's
Old Mar 21, 2007 | 10:38 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Needs to be 4x108 PCD, and offset of ET35, so ET55 will be 20mm too far inset, which means it won't clear the spring cup / damper.
Old Mar 21, 2007 | 10:44 AM
Turbosystems's Avatar
Turbosystems
Super Moderator
et 35-40 min and max
Stavros's Avatar
Stavros
DEYTUKURJERBS
and also look gay like you wont believe.
could just run a 20mm hubcentric spacer then lo and behold, ET35.
Old Mar 21, 2007 | 10:49 AM
Mike Rainbird
Caraholic
Absolutley spot on . Will be around £160 for these, so not a cheap in the end .
Old Mar 21, 2007 | 11:56 AM
Cawood's Avatar
Cawood
thanks again lads
noticed there actually for sale on here as well
sellers name *robrobbo * or something similar
look in alloys for sale
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Iain Mac
Sep 30, 2015 09:39 PM
cossie330
Sep 27, 2015 04:13 PM
ajamesc
Sep 27, 2015 02:25 PM
